跳转到主内容
How to Reattach a Broken Piece of Wood
你所需要的
  1. How to Reattach a Broken Piece of Wood, How to Reattach a Broken Piece of Wood: 步骤 1 中的图像 1,2 How to Reattach a Broken Piece of Wood, How to Reattach a Broken Piece of Wood: 步骤 1 中的图像 2,2
    • Dust the surface of the fragment and the damaged area of the furniture.
    • Any household cleaner will work; we recommend a damp rag.
    • Clean carefully, making sure not to cause further damage by splintering the fragment.
  2. How to Reattach a Broken Piece of Wood: 步骤 2 中的图像 1,2 How to Reattach a Broken Piece of Wood: 步骤 2 中的图像 2,2
    • Check that the fragment fits well into the break in the furniture.
    • If the fragment does not fit perfectly, cut away any irregular slivers on the fragment using a utility knife to achieve as neat of a fit as possible.
  3. How to Reattach a Broken Piece of Wood: 步骤 3 中的图像 1,3 How to Reattach a Broken Piece of Wood: 步骤 3 中的图像 2,3 How to Reattach a Broken Piece of Wood: 步骤 3 中的图像 3,3
    • Apply glue to both the fragment and the furniture.
    • Check that the glue is spread evenly throughout both pieces.
    • Using a brush to spread the glue to all crevices is most effective.
  4. How to Reattach a Broken Piece of Wood: 步骤 4 中的图像 1,2 How to Reattach a Broken Piece of Wood: 步骤 4 中的图像 2,2
    • Insert the wood fragment into the glued spot on the furniture.
  5. How to Reattach a Broken Piece of Wood: 步骤 5 中的图像 1,2 How to Reattach a Broken Piece of Wood: 步骤 5 中的图像 2,2
    • Wipe away any excess glue using a damp rag.
    • Be careful not to move the fragment out of alignment as you are wiping.
  6. How to Reattach a Broken Piece of Wood: 步骤 6 中的图像 1,2 How to Reattach a Broken Piece of Wood: 步骤 6 中的图像 2,2
    • Clamp the two pieces together.
    • You can use any type of clamp that you have on hand. If you don't have a clamp, any type of clip would work.
    • Wait 30 minutes for the glue to dry before removing the clamp.
    • Be careful not to bump the fragment out of alignment as you are clamping.
结论
Continue using furniture as you had before!
3等其他人完成本指南。
Zen Miller
于09/19/16注册
165 声望
撰写一个指南
3条评论
Thank you for the post. It will help me with the leg if a cigar table. However, a piece of wood broke off the front of my mom’s cedar chest and I won’t be able to use a clamp. What do you recommend?
Amanda - 回复
The clean and modern design of our products allows you to use the items for years. we are starting to sale small products and want to get your feedback for these products. We are not the World best online store but we want to be and this is only possible with your response and recommendation.
anita.6j - 回复
Very easy to follow instructions. I've found the most difficult part of any fence build is getting the posts lined up properly and getting them plumb. Even with a line, it can be tough . https://www.whitewooden.com/
White Wooden - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 61
总计 18,555
