跳转到主内容
How to Reattach a Backpack Grab Handle
你所需要的
  1. How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: 步骤 1 中的图像 1,3 How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: 步骤 1 中的图像 2,3 How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: 步骤 1 中的图像 3,3
    • Use a pair of scissors to open the seam on the backpack where the grab handle was torn off.
    • Caution: Be careful when using scissors this way.
  2. How to Reattach a Backpack Grab Handle: 步骤 2 中的图像 1,2 How to Reattach a Backpack Grab Handle: 步骤 2 中的图像 2,2
    • Open up the inner seam at the same spot using a pair of scissors.
  3. How to Reattach a Backpack Grab Handle: 步骤 3 中的图像 1,2 How to Reattach a Backpack Grab Handle: 步骤 3 中的图像 2,2
    • Get your sewing needle and thread with a colour that matches the area on the backpack being repaired.
  4. How to Reattach a Backpack Grab Handle: 步骤 4 中的图像 1,3 How to Reattach a Backpack Grab Handle: 步骤 4 中的图像 2,3 How to Reattach a Backpack Grab Handle: 步骤 4 中的图像 3,3
    • Thread your sewing needle.
    • Make sure your thread is doubled; this makes it more durable and less likely for your stitching to come apart.
  5. How to Reattach a Backpack Grab Handle: 步骤 5 中的图像 1,3 How to Reattach a Backpack Grab Handle: 步骤 5 中的图像 2,3 How to Reattach a Backpack Grab Handle: 步骤 5 中的图像 3,3
    • Hold the edge of your grab handle down at the the first seam you opened.
    • Use the threaded needle to stitch the end of the handle to that spot, then cut off the thread and tie it into a knot.
    • Caution: Sewing needles are sharp; be careful not to poke yourself.
    • This repair only requires one of these two basic stitching methods.
  6. How to Reattach a Backpack Grab Handle: 步骤 6 中的图像 1,2 How to Reattach a Backpack Grab Handle: 步骤 6 中的图像 2,2
    • Hold down the second seam you opened, over the reattached grab handle, and stitch it closed.
    • Use one of these basic stitching methods.
  7. How to Reattach a Backpack Grab Handle: 步骤 7 中的图像 1,3 How to Reattach a Backpack Grab Handle: 步骤 7 中的图像 2,3 How to Reattach a Backpack Grab Handle: 步骤 7 中的图像 3,3
    • Cut off the remaining thread and tie it into a knot.
结论
Once you have completed this guide, you will be able to make use of your grab handle once again.
5等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 110
总计 10,269
