跳转到主内容
How to Reassemble the Palm IIIc
你所需要的
  1. How to Reassemble the Palm IIIc, How to Reassemble the Palm IIIc: 步骤 1 中的图像 1,1
    • Reinsert the screen into the case that contains the buttons.
  2. How to Reassemble the Palm IIIc: 步骤 2 中的图像 1,1
    • Put the Motherboard back into casing from right to left.
    • Make sure the black clips are securing the motherboard into the casing.
  3. How to Reassemble the Palm IIIc: 步骤 3 中的图像 1,3 How to Reassemble the Palm IIIc: 步骤 3 中的图像 2,3 How to Reassemble the Palm IIIc: 步骤 3 中的图像 3,3
    • Secure the bottom two ZIF connectors into their slots by opening the flap and inserting the ZIF connectors.
    • Gently press down on the flap to secure the ZIF connector. This secures the screen and buttons to the motherboard.
  4. How to Reassemble the Palm IIIc: 步骤 4 中的图像 1,2 How to Reassemble the Palm IIIc: 步骤 4 中的图像 2,2
    • Connect the blue and red screen cables to the beige box they were removed from.
  5. How to Reassemble the Palm IIIc: 步骤 5 中的图像 1,2 How to Reassemble the Palm IIIc: 步骤 5 中的图像 2,2
    • Open the ZIF connector box at the top of the motherboard by gently pulling up on the flap.
    • Insert the ZIF tab into the connector box.
    • Gently press down on the flap to secure the ZIF tab in place.
  6. How to Reassemble the Palm IIIc: 步骤 6 中的图像 1,1
    • Attach the white box on the end of the red cable connected to the battery into the connector box on the motherboard.
  7. How to Reassemble the Palm IIIc: 步骤 7 中的图像 1,1
    • Place the front and back covers around the casing containing the motherboard and screen.
    • Before securing the covers, place the sensor in between the front and back cover at the top of the device.
    • After the sensor is in place between the two covers, firmly secure the front and back covers.
  8. How to Reassemble the Palm IIIc: 步骤 8 中的图像 1,1
    • Replace the long screws at the top of the back case with the Philips head screwdriver.
    • Replace the short screws to the bottom of the back case using the Philips head screwdriver.
    • After the screws are in place, insert the stylus.
  9. How to Reassemble the Palm IIIc: 步骤 9 中的图像 1,1
    • Gently snap the flip cover back into place where it connects at the top of the Palm IIIc
终点
另外一个人完成了本指南。
Angela Arthur
于02/16/12注册
101 声望
撰写一个指南
团队
Ohio State, Team 1-5, Buehl Winter 2012 Ohio State, Team 1-5, Buehl Winter 2012 的会员
OSU-BUEHL-W12S1G5
5 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 319
