跳转到主内容
How to Realign a Door Hinge
你所需要的
  1. How to Realign a Door Hinge, How to Realign a Door Hinge: 步骤 1 中的图像 1,3 How to Realign a Door Hinge, How to Realign a Door Hinge: 步骤 1 中的图像 2,3 How to Realign a Door Hinge, How to Realign a Door Hinge: 步骤 1 中的图像 3,3
    • Grab an unaligned door.
    • Either you or a person who is helping hold the door up to the desired position.
  2. How to Realign a Door Hinge: 步骤 2 中的图像 1,3 How to Realign a Door Hinge: 步骤 2 中的图像 2,3 How to Realign a Door Hinge: 步骤 2 中的图像 3,3
    • Grab a hammer and a screwdriver.
    • Hold the screwdriver up to the pin.
    • Hold the hammer below the screwdriver.
    • Knock the pin out of the hinge by banging the screwdriver using the hammer.
  3. How to Realign a Door Hinge: 步骤 3 中的图像 1,3 How to Realign a Door Hinge: 步骤 3 中的图像 2,3 How to Realign a Door Hinge: 步骤 3 中的图像 3,3
    • Drop the pin back into the hinge using the hammer.
    • If the pin gets stuck this means that the knuckles need to be bent back into place.
    • Using pliers bend whichever knuckles need adjusting.
    • Keep bending the knuckles until the pin drops back into place without getting stuck.
  4. How to Realign a Door Hinge: 步骤 4 中的图像 1,1
    • The door should now be in your desired position.
    • To test if the door is back in place, just open and close the door to make sure that the door is in the position you want and functioning correctly.
结论
You have now successfully realigned a door hinge! Good Job
andrea hernandez
于10/23/23注册
109 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 93
总计 656
