跳转到主内容
加入维修社区 - 创建账户
How to Re-Align the Zipper on a Backpack
你所需要的
    1. How to Re-Align the Zipper on a Backpack, How to Re-Align the Zipper on a Backpack: 步骤 1 中的图像 1,1
      • Locate the section of zipper with the problem.
      询问修复机器人
      添加评论
    2. How to Re-Align the Zipper on a Backpack: 步骤 2 中的图像 1,3 How to Re-Align the Zipper on a Backpack: 步骤 2 中的图像 2,3 How to Re-Align the Zipper on a Backpack: 步骤 2 中的图像 3,3
      • Take off the slider by sliding it towards the side without a stopper at the end and pulling it off.
      • Slider: the device that moves up and down the chain to open or close the zipper.
      询问修复机器人
      添加评论
    3. How to Re-Align the Zipper on a Backpack: 步骤 3 中的图像 1,3 How to Re-Align the Zipper on a Backpack: 步骤 3 中的图像 2,3 How to Re-Align the Zipper on a Backpack: 步骤 3 中的图像 3,3
      • Use pliers to remove at least 4 teeth on each side to leave room for a place to sew.
      • Squeezing the handles of the pliers, grab a single zipper tooth and pull it off. This may rip the zipper fabric, but you will sew it together later.
      • Be cautious that you do not get hurt from pulling the pliers back.
      • Small, sharp parts will come off during this procedure. Keep track of these small parts so you can throw them away.
      询问修复机器人
      添加评论
    4. How to Re-Align the Zipper on a Backpack: 步骤 4 中的图像 1,2 How to Re-Align the Zipper on a Backpack: 步骤 4 中的图像 2,2
      • Using thread of similar color to the backpack, insert one end of the thread through the eye of the needle.
      • Let the needle slide down the thread until it hangs at the center. You should have two equal lengths of thread on either side of the needle.
      询问修复机器人
      添加评论
    5. How to Re-Align the Zipper on a Backpack: 步骤 5 中的图像 1,1
      • Tie the loose ends of the thread into a knot
      询问修复机器人
      添加评论
    6. How to Re-Align the Zipper on a Backpack: 步骤 6 中的图像 1,2 How to Re-Align the Zipper on a Backpack: 步骤 6 中的图像 2,2
      • Place the slider back on the zipper.
      • The side of the slider that you feed in first has a divider in the middle.
      • Feed in one side of the zipper in at a time and pull it up to see if the slider can zip up the backpack.
      询问修复机器人
      添加评论
    7. How to Re-Align the Zipper on a Backpack: 步骤 7 中的图像 1,3 How to Re-Align the Zipper on a Backpack: 步骤 7 中的图像 2,3 How to Re-Align the Zipper on a Backpack: 步骤 7 中的图像 3,3
      • After putting the slider back on the zipper, sew the ends of the zipper to prevent the slider from sliding off.
      • Insert the needle through one side of the zipper fabric and pull until it stops at the knot.
      • Then, insert the needle through the other side of the zipper fabric and pull tightly until it seems secure.
      • Repeat this step as many times as needed.
      询问修复机器人
      添加评论
    8. How to Re-Align the Zipper on a Backpack: 步骤 8 中的图像 1,3 How to Re-Align the Zipper on a Backpack: 步骤 8 中的图像 2,3 How to Re-Align the Zipper on a Backpack: 步骤 8 中的图像 3,3
      • Tie a knot to finish it off and cut the excess thread with scissors.
      询问修复机器人
      添加评论
    9. How to Re-Align the Zipper on a Backpack: 步骤 9 中的图像 1,2 How to Re-Align the Zipper on a Backpack: 步骤 9 中的图像 2,2
      • Tuck the zipper inside the flap of the backpack to cover the end of the zipper.
      • Sew the zipper fabric to the backpack to secure it in place.
      添加评论
结论
Test your zipper to see if it is working properly.
取消:我没有完成这个指南。
19等其他人完成本指南。
Emily Liu
于04/28/17注册
647 声望
撰写一个指南
团队
UC Davis, Team S2-G1, Cole Spring 2017 UC Davis, Team S2-G1, Cole Spring 2017 的会员
UCD-COLE-S17S2G1
3 名成员
创作了6篇指南
2指南评论
noice tank u
Tyler Sivongxay - 回复 分享
Thanks i saved some money doing this myself. Grewt instruction
umchocky - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 137
过去 30 天: 504
总计 234,445
