跳转到主内容
How to Propagate a Plant in Water
你所需要的
  1. How to Propagate a Plant in Water, How to Propagate a Plant in Water: 步骤 1 中的图像 1,2 How to Propagate a Plant in Water, How to Propagate a Plant in Water: 步骤 1 中的图像 2,2
    • Using scissors or shears cut the plant below a node.
    • Node: a point where a leaf or branch emerges.
  2. How to Propagate a Plant in Water: 步骤 2 中的图像 1,2 How to Propagate a Plant in Water: 步骤 2 中的图像 2,2
    • Remove the bottom leaves and cut the plant diagonally.
    • Cutting the plant in a diagonal will increase surface area and allow for better water consumption.
  3. How to Propagate a Plant in Water: 步骤 3 中的图像 1,2 How to Propagate a Plant in Water: 步骤 3 中的图像 2,2
    • Optional: Coat the cutting in rooting powder.
    • Rooting powder will accelerate the rooting process and yield a higher success rate.
  4. How to Propagate a Plant in Water: 步骤 4 中的图像 1,1
    • Fill a glass cup with water.
  5. How to Propagate a Plant in Water: 步骤 5 中的图像 1,1
    • Place the cutting in the cup.
    • The cup should be in a well-ventilated area with bright indirect light.
    • Change the water every week to prevent bacterial growth.
  6. How to Propagate a Plant in Water: 步骤 6 中的图像 1,2 How to Propagate a Plant in Water: 步骤 6 中的图像 2,2
    • Once the roots are 1-2 inches long, transfer to medium (soil, lecca, etc.).
    • Water regularly to reduce shock.
结论
You did it! Congratulations on successfully propagating your plant in water!
5等其他人完成本指南。
Daniela Perez
于02/21/24注册
235 声望
撰写一个指南
团队
CSU Sacramento, Team 1-14, Laflen Spring 2024 CSU Sacramento, Team 1-14, Laflen Spring 2024 的会员
CSUSAC-LAFLEN-S24S1G14
2 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 91
总计 1,577
