跳转到主内容
How to Prevent a Run or Tear in Tights from Spreading
你所需要的
  1. How to Prevent a Run or Tear in Tights from Spreading, Run or Tear in Tights: 步骤 1 中的图像 1,2 How to Prevent a Run or Tear in Tights from Spreading, Run or Tear in Tights: 步骤 1 中的图像 2,2
    • Put the ripped tights on for easier repair, or leave them on if you’re already wearing them.
    • Gather clear nail polish and a pair of scissors.
  2. How to Prevent a Run or Tear in Tights from Spreading: 步骤 2 中的图像 1,1
    • Locate all potential runs or directions that the rip can expand.
    • Runs will not usually expand horizontally, but be sure to check both vertical ends of the run.
  3. How to Prevent a Run or Tear in Tights from Spreading: 步骤 3 中的图像 1,1
    • Gently tug the tights away from your skin to prevent the nail polish from affixing to your body.
  4. How to Prevent a Run or Tear in Tights from Spreading: 步骤 4 中的图像 1,2 How to Prevent a Run or Tear in Tights from Spreading: 步骤 4 中的图像 2,2
    • Brush a dollop of clear nail polish on all potential runs.
    • Small runs will require just a dab of nail polish while larger holes may require a thin coat.
    • Repeat these steps to all potential runs and loose threads.
  5. How to Prevent a Run or Tear in Tights from Spreading: 步骤 5 中的图像 1,1
    • Once the nail polish has dried, you may cut any hanging pieces of thread.
    • The nail polish will take about 1 minute to dry.
    • Be sure to complete this step after applying the nail polish and letting it dry or a new run will form.
结论
These steps can save a pair of tights from becoming too tattered for normal use.
另外一个人完成了本指南。
Audrey Fremier
于02/23/15注册
191 声望
撰写一个指南
团队
Cal Poly, Team 12-1, Green Winter 2015 Cal Poly, Team 12-1, Green Winter 2015 的会员
CPSU-GREEN-W15S12G1
6 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 81
过去 30 天: 376
总计 36,223
