跳转到主内容
How to Power Off a Broken Apple Watch
  1. How to Power Off a Broken Apple Watch, Press and hold both buttons: 步骤 1 中的图像 1,2 How to Power Off a Broken Apple Watch, Press and hold both buttons: 步骤 1 中的图像 2,2
    • If your Apple Watch is charging, unplug it from the charger, or this procedure won't work.
    • Press and hold both the side button and digital crown simultaneously.
    • Continue holding while the Apple Watch reboots.
  2. How to Power Off a Broken Apple Watch, Release the digital crown: 步骤 2 中的图像 1,3 How to Power Off a Broken Apple Watch, Release the digital crown: 步骤 2 中的图像 2,3 How to Power Off a Broken Apple Watch, Release the digital crown: 步骤 2 中的图像 3,3
    • When you see the Apple logo, release the digital crown. Continue holding the side button.
    • When the Apple logo disappears, release the side button.
  3. How to Power Off a Broken Apple Watch: 步骤 3 中的图像 1,1
    • The Apple Watch is now powered off.
结论
That’s all! With your Apple Watch safely powered down, you can proceed with repairs.
81等其他人完成本指南。
Jeff Suovanen
于08/06/13注册
447,558 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,788篇指南
8指南评论
Hi Jeff, is this supposed to work with series 3 watches. All I see is the time and a red lightning bolt which then disappears and then reappears
Ed Rutmayer - 回复
Readers,
If a red lightning bolt is on screen, it needs charged. When charging, it’ll turn green. Note: if watch is drained, it may be a bit before it’s green. If watch is blank or has an Apple Magnetic Charger and red bolt, leave it on for 30m. It should be green by then. If not, and using a Non-Apple “knock off” Charger, try an Apple Magnetic Watch Charger, Apple USB Adapter, and a working wall outlet (NOT a laptop or power bank). If it won't charge or reads “accessory isn't supported”, check for plastic films on either side of magnetic charge pad, and remove it. Clean the back of the watch and unplug and disconnect everything for about 10s. Then plug in and try to charge it. Both are magnetic and “stick” together. You should see the green bolt after some charge time. If not, then force restart (Jeff’s step 1) until Apple logo, then let go. No logo? Try another Apple Charger, Apple Adapter, and/or wall outlet. It’s $159 for a screen fix on a $200 watch. If all of this fails, better to just buy a new one.
Alice -
bonjour
comment s
Nacache - 回复
comment savoir si la batterie est defectueuse mon apple watch serie nike +affiche la pomme et celle-ci diparait serait la batterie ou la mise a jour je ne peux la synchroniser avec mon iphone vu qu’elle ne demare plus merci a vous de me rensseigner
Nacache - 回复
do I tail need to power off the watch if its been unused for a long time? my screen is blank and I can not see anything on it
Luis - 回复
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 185
过去 30 天: 815
总计 93,218
