1. Find the power cord.
    • Find the power cord.
    • Make sure that it is unplugged from the outlet. This is to make sure that no power is flowing through and you are not injured.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Check to make sure that the power cord is connected to the device. If it is not connect the smaller end to the back of the device.
    • Check to make sure that the power cord is connected to the device. If it is not connect the smaller end to the back of the device.
  4. Check to make sure that the power cord is connected to an outlet. If not, take the two-pronged end and plug it in to an outlet. The device is now correctly plugged in.
    • Check to make sure that the power cord is connected to an outlet. If not, take the two-pronged end and plug it in to an outlet. The device is now correctly plugged in.
结论
Rosana Cheruvelil
于2012年09月26日注册
63 信誉积分
创作了3篇指南
团队
Cal Poly, Team 7-50, Forte Fall 2012 Cal Poly, Team 7-50, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G50
5 名成员
创作了8篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 196
