跳转到主内容
How to Perform an IBM ThinkPad X60s Fan Spindle Replacement
你所需要的
  1. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement, Fan Spindle: 步骤 1 中的图像 1,1
    • Turn the laptop upside-down, with the battery oriented away.
    • Slide the battery lock switch to the left.
  2. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 2 中的图像 1,1
    • Complete these steps after disconnecting the laptop from power and after powering the laptop down.
    • Simultaneously complete the following:
    • Slide and hold the battery release switch to the right.
    • Push the battery away from you, out of the back of the laptop.
  3. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 3 中的图像 1,3 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 3 中的图像 2,3 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 3 中的图像 3,3
    • Unscrew the black 4mm Phillips #2 screw securing the hard drive enclosure cover.
    • Pull the hard drive enclosure cover up and to the left to expose the hard drive caddy.
    • Pull the hard drive caddy out by the plastic pull tab.
  4. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 4 中的图像 1,3 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 4 中的图像 2,3 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 4 中的图像 3,3
    • Unscrew the two black Phillips #1 screws securing the RAM cover plate.
    • These screws will remain attached to the cover plate.
    • Remove the exposed RAM sticks by prying outward (away from the edges of the RAM sticks) on the securing tabs.
  5. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 5 中的图像 1,1
    • Unscrew the eleven black 6mm Phillips #1 screws securing the keyboard and palmrest.
    • Flip the laptop over.
  6. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 6 中的图像 1,2 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 6 中的图像 2,2
    • Push the keyboard backwards (away from yourself) with both hands.
    • Pry your thumb under the mouse buttons to lift the keyboard upwards (away from the work surface).
    • Pull up to detach the keyboard ribbon tab.
  7. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 7 中的图像 1,2 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 7 中的图像 2,2
    • Pull up to detach the fingerprint scanner ribbon tab.
    • Lift up on the faceplate to remove it.
  8. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 8 中的图像 1,2 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 8 中的图像 2,2
    • Unscrew the five silver 3mm Phillips #1 screws securing the motherboard.
    • Unscrew the silver 7mm Phillips #1 screw securing the motherboard.
  9. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 9 中的图像 1,2 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 9 中的图像 2,2
    • (Optional) Lay a piece of paper, or other protective material, over the laptop screen.
    • Flip the motherboard over onto the screen (or protective material).
    • Flipping the motherboard over should not require forceful motion.
    • Take extreme care not to damage any ribbon cables or wires still connected to the motherboard.
  10. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 10 中的图像 1,3 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 10 中的图像 2,3 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 10 中的图像 3,3
    • Pry back the three metal tabs on the now-exposed underside of the fan housing with needle-nose pliers.
    • Flip the motherboard back over.
  11. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 11 中的图像 1,2 How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: 步骤 11 中的图像 2,2
    • Lift the metal housing off of the fan.
    • There may be foil tape securing the housing. If so, remove it carefully in order to put it back after replacing the fan spindle.
    • Remove and replace the fan spindle.
结论
另外一个人完成了本指南。
Samuel Lees
于02/23/15注册
171 声望
撰写一个指南
团队
Cal Poly, Team 12-2, Green Winter 2015 Cal Poly, Team 12-2, Green Winter 2015 的会员
CPSU-GREEN-W15S12G2
6 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 2,396
