跳转到主内容
How to Perform Circuit Service on the Newport HT70
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
  1. How to Perform Circuit Service on the Newport HT70, Setup: 步骤 1 中的图像 1,1
    • Connect the breathing circuit to the main flow outlet, or as if it were being used for a patient.
    • Cover up the breathing circuit (do not use test lung) .
  2. How to Perform Circuit Service on the Newport HT70, Begin Test: 步骤 2 中的图像 1,1
    • Touch the Circuit Check button at the top of the screen.
    • Press ‘Accept’.
    • Uncover the end of the patient circuit pictured in Step 1.
    • Press the ‘Accept’ button to continue with the circuit check.
    • If test passes, the message “Circuit Check PASSED press accept to confirm” will appear on the screen.
    • If the Circuit check does not pass, do not use the ventilator for patient use. Use an alternate Method of ventilation.
    • If the Circuit Check has failed, there may be an issue with the pump assembly, refer to the “Pump Assembly Replacement” guide to proceed with this diagnosis.
结论
Merek McGill
于04/07/20注册
520 声望
创作了5篇指南
团队
Cal Poly, Team S7-G5, Paton Spring 2020 Cal Poly, Team S7-G5, Paton Spring 2020 的会员
CPSU-PATON-S20S7G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 368
