跳转到主内容
How to Patch a Tear in Vinyl Furniture
你所需要的
  1. How to Patch a Tear in Vinyl Furniture, How to Patch a Tear in Vinyl Furniture: 步骤 1 中的图像 1,1
    • Clean the damaged area with rubbing alcohol, using a rag, paper towel, or Q-tip.
  2. How to Patch a Tear in Vinyl Furniture: 步骤 2 中的图像 1,1
    • Cut the backing fabric large enough to cover the tear, approximately half an inch larger around the tear.
  3. How to Patch a Tear in Vinyl Furniture: 步骤 3 中的图像 1,2 How to Patch a Tear in Vinyl Furniture: 步骤 3 中的图像 2,2
    • Use the spatula tool to insert the backing fabric underneath the tear.
  4. How to Patch a Tear in Vinyl Furniture: 步骤 4 中的图像 1,2 How to Patch a Tear in Vinyl Furniture: 步骤 4 中的图像 2,2
    • Use the spatula to apply the adhesive to the damaged area.
    • Choose a color that matches your furniture. You may need to mix colors to acheive the correct shade.
  5. How to Patch a Tear in Vinyl Furniture: 步骤 5 中的图像 1,1
    • Let the adhesive dry for approximately four hours.
    • You may use a hair dryer to speed up the drying process.
  6. How to Patch a Tear in Vinyl Furniture: 步骤 6 中的图像 1,2 How to Patch a Tear in Vinyl Furniture: 步骤 6 中的图像 2,2
    • Use a Q-tip dipped in rubbing alcohol to buff and blend the area.
    • Apply light pressure to even out the edges.
结论
Once the adhesive is dry, the furniture is ready for use!
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 42
过去 30 天: 200
总计 25,384
