跳转到主内容
How to Patch a Hole in a Kote
你所需要的
  1. How to Patch a Hole in a Kote, How to Patch a Hole in a Kote: 步骤 1 中的图像 1,1
    • Use the ruler to measure the hole, and add a 1/4 to 1/2 inch buffer on all sides.
  2. How to Patch a Hole in a Kote: 步骤 2 中的图像 1,1
    • Use the ruler and pen to create guiding lines for these measurements directly on the backside of the leather patch.
  3. How to Patch a Hole in a Kote: 步骤 3 中的图像 1,1
    • Use the scissors to cut along the guiding lines.
  4. How to Patch a Hole in a Kote: 步骤 4 中的图像 1,1
    • Center the leather patch over the hole and pin it in place.
  5. How to Patch a Hole in a Kote: 步骤 5 中的图像 1,1
    • Cut approximately 30 inches of thread and thread 15 inches through the needle.
    • Tie the two ends of the thread into a square knot by creating a loop, drawing the ends through the loop, and pulling it tight.
  6. How to Patch a Hole in a Kote: 步骤 6 中的图像 1,2 How to Patch a Hole in a Kote: 步骤 6 中的图像 2,2
    • After drawing the thread through the patch from below, about 1/4 inch from the edge, use the thimble to push the needle through the kote, just outside the patch.
    • Use the pliers to pull the needle through the kote and leather.
    • Repeat the process all around the patch until you return to the first stitch.
  7. How to Patch a Hole in a Kote: 步骤 7 中的图像 1,3 How to Patch a Hole in a Kote: 步骤 7 中的图像 2,3 How to Patch a Hole in a Kote: 步骤 7 中的图像 3,3
    • Knot the final stitch in place by running the needle under the first stitch.
    • Pull the thread to create a loop, and run the needle through the loop towards you.
    • To hide the knot, run the needle beneath the patch and pull the thread through, cutting it close to the patch.
  8. How to Patch a Hole in a Kote: 步骤 8 中的图像 1,1
    • You have successfully patched the hole in your kote.
结论
To patch your kote, follow these steps in chronological order.
Dawn Lattin
于06/11/21注册
157 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 40
总计 1,276
