跳转到主内容
How to Patch a Hole in Jeans with Wool
你所需要的
  1. How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: 步骤 1 中的图像 1,3 How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: 步骤 1 中的图像 2,3 How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: 步骤 1 中的图像 3,3
    • Cut a piece of felt large enough to cover the hole
  2. How to Patch a Hole in Jeans with Wool: 步骤 2 中的图像 1,2 How to Patch a Hole in Jeans with Wool: 步骤 2 中的图像 2,2
    • Insert thread through the needle hole.
  3. How to Patch a Hole in Jeans with Wool: 步骤 3 中的图像 1,3 How to Patch a Hole in Jeans with Wool: 步骤 3 中的图像 2,3 How to Patch a Hole in Jeans with Wool: 步骤 3 中的图像 3,3
    • Make a loop at the end of the thread.
    • Pull the end of the thread through the loop creating a knot.
  4. How to Patch a Hole in Jeans with Wool: 步骤 4 中的图像 1,3 How to Patch a Hole in Jeans with Wool: 步骤 4 中的图像 2,3 How to Patch a Hole in Jeans with Wool: 步骤 4 中的图像 3,3
    • Grab the end of the jean with your hand.
    • Pull the jean towards you, making it inside out.
    • Place the felt on the hole.
  5. How to Patch a Hole in Jeans with Wool: 步骤 5 中的图像 1,3 How to Patch a Hole in Jeans with Wool: 步骤 5 中的图像 2,3 How to Patch a Hole in Jeans with Wool: 步骤 5 中的图像 3,3
    • Pinch together the jean and the felt.
    • Insert the needle horizontally into the jean and edge of the felt.
    • Pull the needle through till the knot touches the felt.
    • Repeat the above steps until the border of the felt is stitched.
    • Make a knot at the end.
    • Cut off excess thread.
  6. How to Patch a Hole in Jeans with Wool: 步骤 6 中的图像 1,3 How to Patch a Hole in Jeans with Wool: 步骤 6 中的图像 2,3 How to Patch a Hole in Jeans with Wool: 步骤 6 中的图像 3,3
    • Grasp the end of the jeans and pull them towards you to turn them right side out.
    • Insert the foam board into the pants and position it underneath the hole.
  7. How to Patch a Hole in Jeans with Wool: 步骤 7 中的图像 1,3 How to Patch a Hole in Jeans with Wool: 步骤 7 中的图像 2,3 How to Patch a Hole in Jeans with Wool: 步骤 7 中的图像 3,3
    • Grab more than enough wool to cover the size of your hole, ensuring it is at least an inch thick.
    • Rub the wool between hands to make a ball.
    • Place the wool on top of the hole.
  8. How to Patch a Hole in Jeans with Wool: 步骤 8 中的图像 1,3 How to Patch a Hole in Jeans with Wool: 步骤 8 中的图像 2,3 How to Patch a Hole in Jeans with Wool: 步骤 8 中的图像 3,3
    • Stab the wool through the jean and onto the foam board.
    • Repeat until the wool is hardened.
  9. How to Patch a Hole in Jeans with Wool: 步骤 9 中的图像 1,3 How to Patch a Hole in Jeans with Wool: 步骤 9 中的图像 2,3 How to Patch a Hole in Jeans with Wool: 步骤 9 中的图像 3,3
    • Rub some soap onto the wool to tangle the fibers.
    • Place the jeans into the laundry machine.
    • Wash on cold and air dry.
    • Wear your cute mended pants!
终点
另外一个人完成了本指南。
LiTong Liu
于04/25/24注册
193 声望
撰写一个指南
团队
UC Davis, Team 1-2, Whithaus Spring 2024 UC Davis, Team 1-2, Whithaus Spring 2024 的会员
UCD-WHITHAUS-S24S1G2
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 44
过去 30 天: 102
总计 1,245
