跳转到主内容
加入维修社区 - 创建账户
How to Patch a Hole in Damaged Carpet
你所需要的
    1. How to Patch a Hole in Damaged Carpet, Hole in Carpet: 步骤 1 中的图像 1,3 How to Patch a Hole in Damaged Carpet, Hole in Carpet: 步骤 1 中的图像 2,3 How to Patch a Hole in Damaged Carpet, Hole in Carpet: 步骤 1 中的图像 3,3
      • Place a can over the hole.
      • The can should completely cover the hole.
      询问修复机器人
      添加评论
    2. How to Patch a Hole in Damaged Carpet: 步骤 2 中的图像 1,3 How to Patch a Hole in Damaged Carpet: 步骤 2 中的图像 2,3 How to Patch a Hole in Damaged Carpet: 步骤 2 中的图像 3,3
      • Press down firmly on the can.
      • Cut around the can with a utility knife.
      • Utility knives are sharp, so handle with care.
      • Only cut through the carpet. Do not cut through the carpet pad underneath.
      询问修复机器人
      添加评论
    3. How to Patch a Hole in Damaged Carpet: 步骤 3 中的图像 1,3 How to Patch a Hole in Damaged Carpet: 步骤 3 中的图像 2,3 How to Patch a Hole in Damaged Carpet: 步骤 3 中的图像 3,3
      • Remove the can.
      • Lift out the old carpet.
      询问修复机器人
      添加评论
    4. How to Patch a Hole in Damaged Carpet: 步骤 4 中的图像 1,3 How to Patch a Hole in Damaged Carpet: 步骤 4 中的图像 2,3 How to Patch a Hole in Damaged Carpet: 步骤 4 中的图像 3,3
      • Flip sample carpet onto its back and place down on a stable surface.
      • Place the can onto the sample carpet.
      • Trace the shape of the can with a marker.
      询问修复机器人
      添加评论
    5. How to Patch a Hole in Damaged Carpet: 步骤 5 中的图像 1,3 How to Patch a Hole in Damaged Carpet: 步骤 5 中的图像 2,3 How to Patch a Hole in Damaged Carpet: 步骤 5 中的图像 3,3
      • Remove the can from the sample carpet.
      • Cut out the shape from the sample carpet using scissors.
      • Kitchen scissors are sharp. Always cut away from yourself.
      询问修复机器人
      添加评论
    6. How to Patch a Hole in Damaged Carpet: 步骤 6 中的图像 1,3 How to Patch a Hole in Damaged Carpet: 步骤 6 中的图像 2,3 How to Patch a Hole in Damaged Carpet: 步骤 6 中的图像 3,3
      • Check to make sure the replacement piece of carpet fits into the hole.
      • If necessary, trim sample to fit or cut another piece.
      询问修复机器人
      添加评论
    7. How to Patch a Hole in Damaged Carpet: 步骤 7 中的图像 1,2 How to Patch a Hole in Damaged Carpet: 步骤 7 中的图像 2,2
      • Evenly spread glue on the underside of the replacement carpet.
      • The carpet should be placed down before the glue dries.
      询问修复机器人
      添加评论
    8. How to Patch a Hole in Damaged Carpet: 步骤 8 中的图像 1,2 How to Patch a Hole in Damaged Carpet: 步骤 8 中的图像 2,2
      • Place the glue side of the carpet down into the hole.
      • Press down firmly on the carpet with your hand.
      • Let glue dry before using the carpet.
      询问修复机器人
      添加评论
    9. How to Patch a Hole in Damaged Carpet: 步骤 9 中的图像 1,2 How to Patch a Hole in Damaged Carpet: 步骤 9 中的图像 2,2
      • Trim carpet fibers to blend the replacement carpet with the original.
      询问修复机器人
      添加评论
结论
Once the glue has dried the carpet can be walked on or vacuumed. By cutting the longer carpet fibers the replacement patch should seamlessly blend in with the original carpet.
取消:我没有完成这个指南。
8等其他人完成本指南。
2指南评论
Very good. I suppose if you don't have same carpet you can match as close as possible with a new piece.
Brian Taylor - 回复 分享
Excellent tip - thank you for sharing!!
Rama Narsing - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 71
过去 30 天: 276
总计 29,661
