简介
If your carpet has an unseemly stain, hole, or burn, use this guide to replace the section without the unnecessary fuss and expense of replacing the entire carpet.
Before beginning the fix, make sure the carpet and the sample piece are clean. Some homes have extra matching carpet leftover; however, carpet can always be purchased at a home improvement store.
你所需要的
Once the glue has dried the carpet can be walked on or vacuumed. By cutting the longer carpet fibers the replacement patch should seamlessly blend in with the original carpet.
3等其他人完成本指南。
2条评论
Very good. I suppose if you don't have same carpet you can match as close as possible with a new piece.
Excellent tip - thank you for sharing!!
