跳转到主内容
How to Patch a Burn Hole in a Fabric
你所需要的
  1. How to Patch a Burn Hole in a Fabric, Identify the repair area: 步骤 1 中的图像 1,3 How to Patch a Burn Hole in a Fabric, Identify the repair area: 步骤 1 中的图像 2,3 How to Patch a Burn Hole in a Fabric, Identify the repair area: 步骤 1 中的图像 3,3
    • Locate the burn holes in the garment and gather the tools needed for the repair.
  2. How to Patch a Burn Hole in a Fabric, Prepare the patch: 步骤 2 中的图像 1,3 How to Patch a Burn Hole in a Fabric, Prepare the patch: 步骤 2 中的图像 2,3 How to Patch a Burn Hole in a Fabric, Prepare the patch: 步骤 2 中的图像 3,3
    • Lay your garment on a flat surface.
    • Draw a line around the bottle lid to use it as a guide.
    • Note: In this example, we chose the lid because it was at least 1cm larger than the hole on each side. For future patching, please keep this margin in mind.
  3. How to Patch a Burn Hole in a Fabric, Cut the patches: 步骤 3 中的图像 1,3 How to Patch a Burn Hole in a Fabric, Cut the patches: 步骤 3 中的图像 2,3 How to Patch a Burn Hole in a Fabric, Cut the patches: 步骤 3 中的图像 3,3
    • Use a pair of scissors to cut around the patches and set them aside.
  4. How to Patch a Burn Hole in a Fabric, Place the patch: 步骤 4 中的图像 1,3 How to Patch a Burn Hole in a Fabric, Place the patch: 步骤 4 中的图像 2,3 How to Patch a Burn Hole in a Fabric, Place the patch: 步骤 4 中的图像 3,3
    • Place the top edge of the patch carefully onto the item, and apply gentle pressure.
    • Use the backside of a spoon to apply harder pressure, and use a circular motion to press down around the patch for 1-2 minutes.
  5. How to Patch a Burn Hole in a Fabric, Patch additional holes: 步骤 5 中的图像 1,3 How to Patch a Burn Hole in a Fabric, Patch additional holes: 步骤 5 中的图像 2,3 How to Patch a Burn Hole in a Fabric, Patch additional holes: 步骤 5 中的图像 3,3
    • Look for additional burn holes and repeat the same steps shown before to patch them.
    • Note: Sometimes you will need to patch both the outside and inside part of a garment.
  6. How to Patch a Burn Hole in a Fabric, Finished and ready!: 步骤 6 中的图像 1,2 How to Patch a Burn Hole in a Fabric, Finished and ready!: 步骤 6 中的图像 2,2
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
结论
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
于07/19/23注册
10,230 声望
创作了66篇指南
团队
INTERSPORT INTERSPORT 的会员
Community
25 名成员
创作了169篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 23
过去 30 天: 83
总计 760
