跳转到主内容
How to Operate the Timer Relay Box
你所需要的
  1. How to Operate the Timer Relay Box, Power the box: 步骤 1 中的图像 1,2 How to Operate the Timer Relay Box, Power the box: 步骤 1 中的图像 2,2
    • Connect the box to the mains power using an IEC C13 cable (kettle cable)
    • Check the switch is turned on.
    • Wait a few seconds, the LED under the knob will hold green to indicate the system is operating.
  2. How to Operate the Timer Relay Box, Connect the button trigger: 步骤 2 中的图像 1,1
    • Connect the button cable to the timer box, as shown.
  3. How to Operate the Timer Relay Box, Connect the equipment: 步骤 3 中的图像 1,1
    • Connect the equipment you would like the box to switch on and off.
  4. How to Operate the Timer Relay Box, Set the box to calibration mode: 步骤 4 中的图像 1,1
    • Turn the system off and on using the switch at the power input
    • Push and hold the rotary knob, while the system is being powered on. Release the knob when the LED is solid purple.
    • The LED will begin to flash blue when ready.
  5. How to Operate the Timer Relay Box, Set the trigger delay: 步骤 5 中的图像 1,1
    • Turn the knob clockwise to increase the delay, and counter clockwise to decrease. The delay changes in 0.5 second increments.
    • Turn the knob until the desired delay is achieved.
    • Press the knob to set the delay. The LED will flash green when the delay has been saved.
  6. How to Operate the Timer Relay Box, Set the power delay: 步骤 6 中的图像 1,1
  7. How to Operate the Timer Relay Box, Operate the Timer Box: 步骤 7 中的图像 1,3 How to Operate the Timer Relay Box, Operate the Timer Box: 步骤 7 中的图像 2,3 How to Operate the Timer Relay Box, Operate the Timer Box: 步骤 7 中的图像 3,3
    • Once calibrated, the timer box will switch to operation mode.
    • The LED will hold green when the box is waiting to be triggered.
    • The Box can be triggered through the button wires, or the encoder button
    • Once triggered, the LED will turn amber for the initial delay
    • The LED will turn RED when the equipment is being powered.
    • The LED will return to green once the system is ready to be triggered again.
    • Cycle the power, and trigger the system to ensure the calibration has been saved.
结论
James Schreiber
于02/10/22注册
230 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 278
