跳转到主内容
How to Open the Left Handle of the Backbone One
你所需要的
  1. How to Open the Left Handle of the Backbone One, Unfasten the screws: 步骤 1 中的图像 1,1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. How to Open the Left Handle of the Backbone One, Rotate the upper cover: 步骤 2 中的图像 1,3 How to Open the Left Handle of the Backbone One, Rotate the upper cover: 步骤 2 中的图像 2,3 How to Open the Left Handle of the Backbone One, Rotate the upper cover: 步骤 2 中的图像 3,3
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
  3. How to Open the Left Handle of the Backbone One, Remove the protective tape: 步骤 3 中的图像 1,3 How to Open the Left Handle of the Backbone One, Remove the protective tape: 步骤 3 中的图像 2,3 How to Open the Left Handle of the Backbone One, Remove the protective tape: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
  4. How to Open the Left Handle of the Backbone One, Open the ZIF connector: 步骤 4 中的图像 1,2 How to Open the Left Handle of the Backbone One, Open the ZIF connector: 步骤 4 中的图像 2,2
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
  5. How to Open the Left Handle of the Backbone One, Disconnect the interconnect cable: 步骤 5 中的图像 1,2 How to Open the Left Handle of the Backbone One, Disconnect the interconnect cable: 步骤 5 中的图像 2,2
    • Use your fingers to disconnect the interconnect cable from its connector.
  6. How to Open the Left Handle of the Backbone One: 步骤 6 中的图像 1,2 How to Open the Left Handle of the Backbone One: 步骤 6 中的图像 2,2
    • Remove the upper half of the left controller assembly.
结论
Opening didn’t go as planned? Answers community for help.
Adriana Zwink
于12/18/19注册
62,406 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,735篇指南
2指南评论
Did this work for you?
Shawn Gallant - 回复
Shawn Gallant - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 34
总计 1,642
