跳转到主内容
How to Open the Fitbit Charge 2
你所需要的
  1. How to Open the Fitbit Charge 2, Remove the watch band: 步骤 1 中的图像 1,1
    • Before starting, take your Fitbit Charge 2 off the charger and power it down.
    • Remove the watch band on both sides.
  2. How to Open the Fitbit Charge 2, Heat the touch screen: 步骤 2 中的图像 1,1
    • Heat an iOpener and apply it to the touch screen for two minutes.
    • The screen is not glued down, but the heat helps to loosen the touch screen assembly from your watch.
  3. How to Open the Fitbit Charge 2, Slide along the left edge: 步骤 3 中的图像 1,3 How to Open the Fitbit Charge 2, Slide along the left edge: 步骤 3 中的图像 2,3 How to Open the Fitbit Charge 2, Slide along the left edge: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    iSesamo Opening Tool
    $9.99
    • Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
    • Slide the iSesamo along the left edge to the bottom left corner.
  4. How to Open the Fitbit Charge 2, Slide along the bottom edge: 步骤 4 中的图像 1,2 How to Open the Fitbit Charge 2, Slide along the bottom edge: 步骤 4 中的图像 2,2
    • Slide the iSesamo around the bottom left corner.
    • Slide it along the edge to the bottom right corner.
  5. How to Open the Fitbit Charge 2: 步骤 5 中的图像 1,3 How to Open the Fitbit Charge 2: 步骤 5 中的图像 2,3 How to Open the Fitbit Charge 2: 步骤 5 中的图像 3,3
    • Slide the iSesamo around the bottom right corner.
    • Keep sliding it along the right edge to the top right corner.
  6. How to Open the Fitbit Charge 2: 步骤 6 中的图像 1,2 How to Open the Fitbit Charge 2: 步骤 6 中的图像 2,2
    • Slide the iSesamo around the top right corner.
    • Slide it along the top edge to the top left corner.
  7. How to Open the Fitbit Charge 2: 步骤 7 中的图像 1,2 How to Open the Fitbit Charge 2: 步骤 7 中的图像 2,2
    • Place the iSesamo under the top left corner.
    • Feel free to reattach the watch band for this and the next step for a better grip.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
  8. How to Open the Fitbit Charge 2: 步骤 8 中的图像 1,2 How to Open the Fitbit Charge 2: 步骤 8 中的图像 2,2
    • Place the iSesamo under the top right corner.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
  9. How to Open the Fitbit Charge 2: 步骤 9 中的图像 1,2 How to Open the Fitbit Charge 2: 步骤 9 中的图像 2,2
    • Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
    • Use the spudger to pry up the touch screen assembly.
    • Do not remove the touch screen assembly all the way yet—it's still connected to the motherboard.
  10. How to Open the Fitbit Charge 2: 步骤 10 中的图像 1,1
    • Carefully fold the touch screen assembly in the direction of the bottom edge.
结论
Opening didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
于12/18/19注册
62,199 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,649篇指南
1指南评论
How do I get the daughterboard out?
Pospesel - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 46
总计 6,475
