跳转到主内容
How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator)
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator), How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 1 中的图像 1,1
    • Remove the covering cap. (pg. 23)
  2. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 2 中的图像 1,1
    • Place the unit upside down on a non-slip surface and remove the six screws. (pg. 23)
  3. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 3 中的图像 1,1
    • Remove the lower part of the housing with a swiveling motion away to the side. Note the SOMNOcomfort series uses a shorter circuit board than the balance series ventilator. (pg. 23)
  4. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 4 中的图像 1,3 How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 4 中的图像 2,3 How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 4 中的图像 3,3
    • Remove the connector (X1) from the circuit board.
    • Pull the connecting cable (64) from its mount.
    • Now set aside the lower part of the housing. (pg. 23)
  5. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 5 中的图像 1,2 How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 5 中的图像 2,2
    • Next, how to close the compartment and reverse the process.
    • Hold the lower part of the housing to the upper part at an angle
    • Attach the connector (X1) to the main circuit board. When doing so the connector’s nub has to point towards the lock. (pg. 24)
  6. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 6 中的图像 1,2 How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 6 中的图像 2,2
    • Properly align the main circuit board inside the unit.
    • Attach the connecting cable (64) to its mount (pg. 24)
  7. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 7 中的图像 1,1
    • Place the lower part of the housing on the upper part (47). Please make sure the main circuit board (44) is aligned properly, and that the connecting cable (64) is not being squeezed anywhere. (pg. 24)
  8. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 8 中的图像 1,1
    • Now reattach the upper part of the housing by tightening the six screws. (pg. 24)
  9. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 9 中的图像 1,1
    • Insert the covering cap. (pg. 24)
结论
Now, you can properly assemble and reassemble the SOMNOcomfort and SOMNObalance ventilators in order to perform and necessary repairs.
Diya Jamwal
于11/07/18注册
553 声望
创作了3篇指南
团队
Cal Poly, Team S1-G3, Zimmerman Spring 2020 Cal Poly, Team S1-G3, Zimmerman Spring 2020 的会员
CPSU-ZIMMERMAN-S20S1G3
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 194
