跳转到主内容
How to Open Logitech Harmony 1100
你所需要的
  1. How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: 步骤 1 中的图像 1,2 How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: 步骤 1 中的图像 2,2
    • Remove the battery cover by pushing down on the circled areas and pushing outward.
    • Remove the battery by lifting up the battery on the corner exposed by the indent in the case
  2. How to Open Logitech Harmony 1100: 步骤 2 中的图像 1,1
    • Use a J0 screwdriver head
    • Remove the 3 screws from battery compartment
  3. How to Open Logitech Harmony 1100: 步骤 3 中的图像 1,2 How to Open Logitech Harmony 1100: 步骤 3 中的图像 2,2
    • Open the connector port on the side.
    • Remove screw with a PH00 screwdriver head.
  4. How to Open Logitech Harmony 1100: 步骤 4 中的图像 1,3 How to Open Logitech Harmony 1100: 步骤 4 中的图像 2,3 How to Open Logitech Harmony 1100: 步骤 4 中的图像 3,3
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • The plastic connector door will fall off. It will need to be put back upon reassembly.
结论
另外一个人完成了本指南。
Keegan Williams
于02/19/16注册
216 声望
创作了2篇指南
团队
Ohio State, Team 1-5, Garvin Spring 2016 Ohio State, Team 1-5, Garvin Spring 2016 的会员
OSU-GARVIN-S16S1G5
3 名成员
创作了3篇指南
1指南评论
Will changing the battery reset the settings within the remote?
wiboman AT gmail DOT com
Wibo Lammerts - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,558
