跳转到主内容
How to Mend a Tear Using Sashiko Stitching
你所需要的
  1. How to Mend a Tear Using Sashiko Stitching, How to Mend a Tear Using Sashiko Stitching: 步骤 1 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching, How to Mend a Tear Using Sashiko Stitching: 步骤 1 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching, How to Mend a Tear Using Sashiko Stitching: 步骤 1 中的图像 3,3
    • Cut away any loose threads around the tear.
  2. How to Mend a Tear Using Sashiko Stitching: 步骤 2 中的图像 1,2 How to Mend a Tear Using Sashiko Stitching: 步骤 2 中的图像 2,2
    • Measure how big your patch should be.
    • Your patch should extend at least half an inch past the tear.
  3. How to Mend a Tear Using Sashiko Stitching: 步骤 3 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 3 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 3 中的图像 3,3
    • Cut your patch using measurements from Step 2.
    • You can use any sturdy fabric for your patch.
  4. How to Mend a Tear Using Sashiko Stitching: 步骤 4 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 4 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 4 中的图像 3,3
    • Pin your patch to the inside of the garment.
    • Make sure the patch is centered on the tear.
    • Be careful pushing pins through to not poke yourself.
  5. How to Mend a Tear Using Sashiko Stitching: 步骤 5 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 5 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 5 中的图像 3,3
    • Flip the garment right side out.
    • Over the patch, mark small dashes every half inch, horizontally and vertically.
    • These marks should create small crosses to guide your stitches later on.
    • We used a regular ballpoint pen in this step, but for a less permanent mark we recommend using tailor’s chalk or specific fabric pens that will wash out.
  6. How to Mend a Tear Using Sashiko Stitching: 步骤 6 中的图像 1,2 How to Mend a Tear Using Sashiko Stitching: 步骤 6 中的图像 2,2
    • Thread your needle and pull the thread through at least 5 inches.
    • Wetting and pinching the end of the thread can help fit the thread through the eye of the needle.
  7. How to Mend a Tear Using Sashiko Stitching: 步骤 7 中的图像 1,1
    • Cut the thread to a single arm’s length.
    • The length should be manageable to you; shorter is better than longer.
  8. How to Mend a Tear Using Sashiko Stitching: 步骤 8 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 8 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 8 中的图像 3,3
    • Tie a double knot at the end of your thread.
    • Trim off any excess.
  9. How to Mend a Tear Using Sashiko Stitching: 步骤 9 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 9 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 9 中的图像 3,3
    • Start your stitch from the inside of the garment, beginning at the top right horizontal stitch.
  10. How to Mend a Tear Using Sashiko Stitching: 步骤 10 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 10 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 10 中的图像 3,3
    • Start your horizontal stitch, going over the marks, and under the gaps.
  11. How to Mend a Tear Using Sashiko Stitching: 步骤 11 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 11 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 11 中的图像 3,3
    • After a couple stitches, pull your needle and thread all the way through.
    • Smooth out your stitches to avoid bunching.
  12. How to Mend a Tear Using Sashiko Stitching: 步骤 12 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 12 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 12 中的图像 3,3
    • Repeat steps 10 and 11 until you reach the end of the first row.
  13. How to Mend a Tear Using Sashiko Stitching: 步骤 13 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 13 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 13 中的图像 3,3
    • On the last stitch of a row, stitch down to start the next row.
    • You may need to rotate the garment between rows to make stitching easier.
  14. How to Mend a Tear Using Sashiko Stitching: 步骤 14 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 14 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 14 中的图像 3,3
    • Repeat steps 10 through 13 until all horizontal stitches are done.
    • On the last stitch, push the needle through to the inside of the garment.
  15. How to Mend a Tear Using Sashiko Stitching: 步骤 15 中的图像 1,2 How to Mend a Tear Using Sashiko Stitching: 步骤 15 中的图像 2,2
    • Remove the pins from the patch.
  16. How to Mend a Tear Using Sashiko Stitching: 步骤 16 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 16 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 16 中的图像 3,3
    • Make a small stitch through just the patch, right next to where the needle came through.
    • Pull the thread almost all the way through, leaving a small loop.
  17. How to Mend a Tear Using Sashiko Stitching: 步骤 17 中的图像 1,2 How to Mend a Tear Using Sashiko Stitching: 步骤 17 中的图像 2,2
    • Pull the needle through the loop twice.
  18. How to Mend a Tear Using Sashiko Stitching: 步骤 18 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 18 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 18 中的图像 3,3
    • Pull the thread tight to knot off.
    • Trim any excess thread.
  19. How to Mend a Tear Using Sashiko Stitching: 步骤 19 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 19 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 19 中的图像 3,3
    • Begin your vertical stitches, starting at the top right corner.
    • You may need to start a new thread; see Steps 6-8.
  20. How to Mend a Tear Using Sashiko Stitching: 步骤 20 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 20 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 20 中的图像 3,3
    • Repeat Steps 10-13 along your vertical stitch marks.
  21. How to Mend a Tear Using Sashiko Stitching: 步骤 21 中的图像 1,3 How to Mend a Tear Using Sashiko Stitching: 步骤 21 中的图像 2,3 How to Mend a Tear Using Sashiko Stitching: 步骤 21 中的图像 3,3
    • On your last stitch, push your needle through to the inside.
  22. How to Mend a Tear Using Sashiko Stitching: 步骤 22 中的图像 1,2 How to Mend a Tear Using Sashiko Stitching: 步骤 22 中的图像 2,2
  23. How to Mend a Tear Using Sashiko Stitching: 步骤 23 中的图像 1,2 How to Mend a Tear Using Sashiko Stitching: 步骤 23 中的图像 2,2
  24. How to Mend a Tear Using Sashiko Stitching: 步骤 24 中的图像 1,2 How to Mend a Tear Using Sashiko Stitching: 步骤 24 中的图像 2,2
结论
You have now successfully mended your garment! Revisit this guide to mend other garments with any holes or tears.
TaShun Blanchard
于02/19/25注册
349 声望
撰写一个指南
团队
UC Davis, Team 3-5, Andersen Winter 2025 UC Davis, Team 3-5, Andersen Winter 2025 的会员
UCD-ANDERSEN-W25S3G5
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 102
总计 495
