跳转到主内容
How to Mend a Hole in a Cotton Blanket
你所需要的
  1. How to Mend a Hole in a Cotton Blanket, How to Mend a Hole in a Cotton Blanket: 步骤 1 中的图像 1,1
    • Find the hole in the blanket
  2. How to Mend a Hole in a Cotton Blanket: 步骤 2 中的图像 1,1
    • Put the needle through the blanket, right below the hole picking up just a little bit of the fabric and do not pull the thread all the way through.
  3. How to Mend a Hole in a Cotton Blanket: 步骤 3 中的图像 1,2 How to Mend a Hole in a Cotton Blanket: 步骤 3 中的图像 2,2
    • Repeat step 2 about 2 more times by inserting the needle through the same hole
  4. How to Mend a Hole in a Cotton Blanket: 步骤 4 中的图像 1,1
    • On the last you pull, do not pull all the way for it creates a loop. Put your needle through the loop, pull the thread all the way and this creates a secure knot.
  5. How to Mend a Hole in a Cotton Blanket: 步骤 5 中的图像 1,3 How to Mend a Hole in a Cotton Blanket: 步骤 5 中的图像 2,3 How to Mend a Hole in a Cotton Blanket: 步骤 5 中的图像 3,3
    • Pick one side of the hole and go through to the other side while picking up fabric from the other side and pull our thread through all the way.
  6. How to Mend a Hole in a Cotton Blanket: 步骤 6 中的图像 1,1
    • Repeat step 5 going in an upward direction until you have reached the top of the hole.
  7. How to Mend a Hole in a Cotton Blanket: 步骤 7 中的图像 1,1
    • The last thread you pull through, do not pull all the way but instead put your need through the loop it creates and create a secure knot. Repeat this step about 2-3 more times threading through the same hole to create an extra secure knot.
  8. How to Mend a Hole in a Cotton Blanket: 步骤 8 中的图像 1,1
    • Snip off the thread and make sure the hole has been mended. You can clean it up by trimming any loose fabric.
终点
Kiara Lee
于09/11/21注册
157 声望
撰写一个指南
团队
York University, Team E-10, Melo-Thaiss Fall 2021 York University, Team E-10, Melo-Thaiss Fall 2021 的会员
YORK-MELO-THAISS-F21SEG10
1 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 147
总计 6,894
