跳转到主内容
How to Manually Eject a Stuck Disc in a PlayStation 4
你所需要的
  1. How to Manually Eject a Stuck Disc in a PlayStation 4, Removing the Cover: 步骤 1 中的图像 1,2 How to Manually Eject a Stuck Disc in a PlayStation 4, Removing the Cover: 步骤 1 中的图像 2,2
    • Use your hands to remove the shiny part of the PS4 cover. It should come off rather easily.
    • As you can see in the second image, the cover should just pull of with ease, and a little force.
    • IF YOU ARE STRUGGLING TO REMOVE THIS COVER, PLACE THE PLAY-STATION ON A RAISED LEDGE TO GIVE YOURSELF A LITTLE MORE LEVERAGE
  2. How to Manually Eject a Stuck Disc in a PlayStation 4, Locating Phillips Screw: 步骤 2 中的图像 1,1
    • There is a small black screw located in-between the vents. You will see two sections of tightly packed slots and on single slot somewhat separated. This is where the screw is located.
    • PLEASE BE CAREFUL WITH THIS SCREW AS IT IS VERY EASY TO BE ROUNDED OFF.
  3. How to Manually Eject a Stuck Disc in a PlayStation 4, Rotate Counter-clockwise: 步骤 3 中的图像 1,1
    • Use a Phillips screwdriver and rotate the screw counter-clockwise. This shouldn't require very much pressure and you should see the stuck disc slowly come out of its slot after a few twists.
    • THE MORE PRESSURE THAT YOU USE, THE MORE CHANCE YOU RUN OF ROUNDING OFF THE HEAD
    • That is it! You are now done!
结论
17等其他人完成本指南。
Kyle Webb
于05/07/19注册
1,181 声望
撰写一个指南
4条评论
Very informative! Even though I resolved my disc issue the other way that you said, I wanted to do it this way after, just in case I come across the issue again, and it was very easy to do following your guide. Thanks!
MobGuru - 回复
Does this method work for the CUH-1215a model?
james_frazier16 - 回复
Not Wirkung Disc is still in!
Detlev Szarafinski - 回复
Look for a screw with the PlayStation symbol on it. With a screwdriver, turn the screw counterclockwise to remove it from the hard disk drive (HDD).
Pull the HDD part-way out from the console, revealing the manual eject hole.
Insert a screwdriver inside the manual eject hole, turning clockwise to release the disc.
blaczacthasage - 回复
添加评论
浏览统计数据:
过去 24 小时: 56
过去 7 天: 296
过去 30 天: 1,427
总计 49,018
