跳转到主内容
How to Manually Configure Timer Relay Box
你所需要的
  1. How to Manually Configure Timer Relay Box, Access Config files: 步骤 1 中的图像 1,1
    • Connect the microcontroller to any computer.
    • The device will pop up as a removable disk. Open the drive.
    • Open the config folder
  2. How to Manually Configure Timer Relay Box, Reconfigure Delay Settings: 步骤 2 中的图像 1,3 How to Manually Configure Timer Relay Box, Reconfigure Delay Settings: 步骤 2 中的图像 2,3 How to Manually Configure Timer Relay Box, Reconfigure Delay Settings: 步骤 2 中的图像 3,3
    • Open trigger.py in any plain text editor.
    • Edit the value (seconds) to change the delay before the device is powered on.
    • Open power.py in any plain text editor.
    • Change the value (seconds) to change the delay the device is powered on for.
结论
Reassemble the device.
James Schreiber
于02/10/22注册
230 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 92
