简介
Soldering creates fumes that are better left un-inhaled. If you're tired of holding your breath or "playing dodge the fumes" then this affordable and simple fume extractor is for you.
Best of all, it's made from parts you probably have laying around. The only specialty part that you may need to order is the activated carbon filter. This guide uses Hakko A1001 filters.
你所需要的
Position the fan over the box so that an exhaust cutout can be made.
Use a pointy object like a screwdriver to poke four fan mounting holes into the box.
Use a pen or pencil to mark the inside diameter of the fan onto the box.
Poke four more holes about 1 cm out from the ones you made earlier.
Flip the box over.
Use a pen or a pencil and a straight edge to mark out the intake port.
Thread four zip ties through the fan mounting holes.
Thread the zip ties through the fan's mounting holes.
Secure the fan to the exhaust port by tightening the zip ties.
Clip the excess zip tie strap.
Note and remember the power and ground pins on the fan connector.
Cut off the fan connector.
Use a pointy object like a screwdriver to poke a hole in the box for the fan cable.
Thread the fan cable into the box.
Use a pen or pencil to mark the outline of the switch.
Cut out a hole for the switch.
Pull the fan cable through the switch hole.
Solder the switch between the fan's positive wire and the battery's positive wire.
Solder the negative fan wire to the negative battery wire.
Pull the excess cable back through and mount the switch to the box.
Place the loose wires in the box.
Secure the 9V battery to the interior of the box using double sided tape.
Rejoice! The days of holding your breath or inhaling solder fumes are over.
Now that you've created a fume extractor, check out some of our soldering guides or stop by our store for supplies you might need on your soldering journey.
38等其他人完成本指南。
14指南评论
how long will the battery last? why not use a battery connector? so changing out the battery would be a lot easier.
they do, it's easiest to see in the step 1 photo, but it's also there in step 17
X2Brute -
Why not put the fan in the box?
Why not reduce the inlet opening to the size of a smoke filter and thus save a filter?
Why not indeed! I hear a v2 in the making :)
