跳转到主内容
How to Make a Jeans Patch Less Noticeable
你所需要的
  1. How to Make a Jeans Patch Less Noticeable, How to Make a Jeans Patch Less Noticeable: 步骤 1 中的图像 1,2 How to Make a Jeans Patch Less Noticeable, How to Make a Jeans Patch Less Noticeable: 步骤 1 中的图像 2,2
    • Place the jeans on an even surface.
    • Flip your jeans inside out.
  2. How to Make a Jeans Patch Less Noticeable: 步骤 2 中的图像 1,3 How to Make a Jeans Patch Less Noticeable: 步骤 2 中的图像 2,3 How to Make a Jeans Patch Less Noticeable: 步骤 2 中的图像 3,3
    • Trim any loose thread around the hole.
    • After cleaning the area, use the iron to warm the area before placing the patch.
  3. How to Make a Jeans Patch Less Noticeable: 步骤 3 中的图像 1,2 How to Make a Jeans Patch Less Noticeable: 步骤 3 中的图像 2,2
    • Grab the patch and iron it on until it is secured to the jeans.
  4. How to Make a Jeans Patch Less Noticeable: 步骤 4 中的图像 1,3 How to Make a Jeans Patch Less Noticeable: 步骤 4 中的图像 2,3 How to Make a Jeans Patch Less Noticeable: 步骤 4 中的图像 3,3
    • Start preparing your thread and needle and knot the end of the thread.
    • Push the needle from the back to the front.
    • Create an outline of the part where the patch is visible, until a circle is formed.
  5. How to Make a Jeans Patch Less Noticeable: 步骤 5 中的图像 1,3 How to Make a Jeans Patch Less Noticeable: 步骤 5 中的图像 2,3 How to Make a Jeans Patch Less Noticeable: 步骤 5 中的图像 3,3
    • Push the needle from the back to the front, filling in the hole.
    • Repeat this process until the hole is covered and the patch is not showing.
    • Tie off the thread in a knot on the inside of the jeans.
  6. How to Make a Jeans Patch Less Noticeable: 步骤 6 中的图像 1,2 How to Make a Jeans Patch Less Noticeable: 步骤 6 中的图像 2,2
    • Grabbing a new color thread, tie off a knot like mentioned in step 4.
    • Starting inside, create your desired design (we decided a moon and stars).
    • Push the needle back to front creating little clumps within the hole.
    • When you have finished the design tie it off on the inside of the jeans.
  7. How to Make a Jeans Patch Less Noticeable: 步骤 7 中的图像 1,1
    • Cut a new piece of thread and place it on the inside.
    • Push the needle back to front of the jeans and push it back inside a few centimeters down.
    • Repeat this threading technique a few times, creating a star.
    • Tie off the thread on the inside of the jean.
    • Cut any excess thread from the inside of the jean.
    • Jeans are now ready to be worn.
终点
Alejandra Gonzalez Manzo
于04/22/24注册
145 声望
撰写一个指南
团队
UC Davis, Team 2-5, Whithaus Spring 2024 UC Davis, Team 2-5, Whithaus Spring 2024 的会员
UCD-WHITHAUS-S24S2G5
3 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 65
总计 552
