跳转到主内容
How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill
你所需要的
  1. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill, How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: 步骤 1 中的图像 1,1
    • Unplug the treadmill from the wall outlet before you begin.
    • Loosen the screws in the deck of the treadmill at the edge of the machine using a screwdriver.
  2. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: 步骤 2 中的图像 1,1
    • Gently lift the belt.
  3. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: 步骤 3 中的图像 1,1
    • Take a clean cloth to wipe out any dust or debris.
  4. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: 步骤 4 中的图像 1,1
    • Apply lubricant under the belt, starting from the center and working your way to the edge.
    • Wear gloves as the lubricant is filled with chemicals.
  5. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: 步骤 5 中的图像 1,1
    • Tighten the screws in the treadmill deck using a screwdriver.
  6. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: 步骤 6 中的图像 1,1
    • Start the treadmill again and ensure it works without creaking noises.
结论
You did it! Oiling your treadmill is an essential maintenance task that ensures the longevity and optimal performance of your equipment. Regularly oiling the machine helps to reduce friction, noise, and wear and tear on the moving parts, making your workouts safer and more comfortable. Neglecting this task can lead to serious damage to your treadmill, which can be expensive to repair or replace. Therefore, it is recommended that you oil your treadmill every three to six months, depending on how frequently you use it. By taking good care of your equipment, you can enjoy a smooth and hassle-free treadmill workout for years to come.
另外一个人完成了本指南。
Batul Ismail
于05/25/23注册
133 声望
撰写一个指南
团队
York University, Team A-4, Allen Summer 2023 York University, Team A-4, Allen Summer 2023 的会员
YORK-ALLEN-SU23SAG4
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 132
