跳转到主内容
How to Lengthen a Necklace Chain
你所需要的
  1. How to Lengthen a Necklace Chain, How to Lengthen a Necklace Chain: 步骤 1 中的图像 1,1
    • Measure and determine the desired length of jewelry chain that you want to add.
    • Place a piece of tape to mark where you want to cut.
  2. How to Lengthen a Necklace Chain: 步骤 2 中的图像 1,1
    • Cut the extender chain with wire cutters/scissors at the tape marker.
  3. How to Lengthen a Necklace Chain: 步骤 3 中的图像 1,1
    • Look at your jump ring. If there is no opening in the jump ring, carefully cut the ring yourself with scissors.
  4. How to Lengthen a Necklace Chain: 步骤 4 中的图像 1,1
    • Use jewelry pliers to open the jump ring at one end of the extender chain and one end of the jewelry chain.
  5. How to Lengthen a Necklace Chain: 步骤 5 中的图像 1,1
    • Connect one end of the extender chain to the jump rings.
    • Repeat the process by attaching one end of the jewelry chain to the same jump ring the extender chain is on.
  6. How to Lengthen a Necklace Chain: 步骤 6 中的图像 1,1
    • With the jewelry pliers, carefully squeeze the jump ring shut, ensuring both the extender chain and jewelry chain remain securely attached to it.
  7. How to Lengthen a Necklace Chain: 步骤 7 中的图像 1,1
    • Make sure that the extender chain's closure is secure and won’t open or come loose during wear. If everything seems correct, you are ready to wear it!
终点
Faith Low
于04/26/24注册
145 声望
撰写一个指南
团队
UC Davis, Team 2-3, Whithaus Spring 2024 UC Davis, Team 2-3, Whithaus Spring 2024 的会员
UCD-WHITHAUS-S24S2G3
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 24
总计 54
