跳转到主内容
How to Iron a Waterproof Jacket
你所需要的
  1. How to Iron a Waterproof Jacket, How to Iron a Waterproof Jacket: 步骤 1 中的图像 1,1
    • Unzip your clean jacket and slide one half over your ironing board.
    • You only want to iron through one layer of the jacket. Ironing through two layers can create wrinkles in one side.
    • Flatten your jacket with your hands.
    I was not aware that this type of jackets can be ironed also.
    Dineo Futho - 回复
  2. How to Iron a Waterproof Jacket: 步骤 2 中的图像 1,3 How to Iron a Waterproof Jacket: 步骤 2 中的图像 2,3 How to Iron a Waterproof Jacket: 步骤 2 中的图像 3,3
    • Set your iron to its lowest setting.
    • Ensure that the steam function of your iron is off.
    • Steam can melt your jacket. If you can't turn off the steam function on your iron, be sure to drain the water chamber of your iron.
  3. How to Iron a Waterproof Jacket: 步骤 3 中的图像 1,2 How to Iron a Waterproof Jacket: 步骤 3 中的图像 2,2
    • Lay a towel over the area of your jacket that you'll be ironing.
    • Smooth the towel out with your hands.
  4. How to Iron a Waterproof Jacket: 步骤 4 中的图像 1,2 How to Iron a Waterproof Jacket: 步骤 4 中的图像 2,2
    • Starting near the center, iron the jacket in one smooth stroke running parallel to the zipper.
    • Only iron in one direction. Each stroke should go in the same direction. Change directions only when you move to a new section of the jacket.
    • Do not press down with the iron. Allow the heat and weight of the iron to do the work.
    • Always keep the iron moving. Stopping in one place can result in burnt fabric.
  5. How to Iron a Waterproof Jacket: 步骤 5 中的图像 1,3 How to Iron a Waterproof Jacket: 步骤 5 中的图像 2,3 How to Iron a Waterproof Jacket: 步骤 5 中的图像 3,3
    • Remove the towel from your jacket.
    • Inspect your work.
    • If it looks as though the iron did nothing, you can increase the heat of your iron by one setting and try ironing again.
    • If your work looks good, position another section of the jacket flat on the ironing board, re-cover it with the towel and repeat the process until your whole jacket is wrinkle-free.
    • Don't forget to turn off the iron when you finish.
    Thanks very much for your great sharing! It is indeed really helpful. I was wondering how to clear the “wrinkles” on rain jackets we have newly bought for hiking use.
    AILEEN WONG - 回复
    thank you so much yall helped me out a lot
    Aura Mothoa - 回复
    Great advice…really helpful…! Thank you..:-)
    Caroline Falvey - 回复
    Helpful! But I am wondering if a jacket that is old has that gray waterproofing fused lining disintegrating at the neckline where the hood comes but is otherwise okay, could any fusible patch work? (It is not Patagonia). beinzig6@gmail.com
    Barbara Einzig - 回复
    and after all this, is it still waterproof. no mention of reproof g it. wondering as other sites, from the people that actually create the jackets, says no. do t do it. as it affects the waterproofness. which is, as we know... the whole point of the said jacket
    Tracy Cooper - 回复
终点
19等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
13条评论
Thank you, good advice for younger generation who have clue.
keirakeith26 - 回复
Thank you - good reminder for the older generation who have lost their marbles
Swag McYolo - 回复
Thank you- good reminder for the baby boomer middle aged who voted for Brexit and haven't got a clue.
fixxysugar - 回复
謝謝,對於說中文的外國人來說,這是一個很好的建議,即使他們沒有失去彈珠,他們也沒有投棄權,但仍然沒有任何線索。
艾爾伯特愛因斯坦 - 回复
I hope the non-English comment is also in the same form as the first 3.
Eva - 回复
Thank you, good reminder for the younger cotton pickers who had no idea how! And shoutout to the caveman too!
Dany Biresom - 回复
Thank you, good advice for the greek single 30year old, who is too old to be asking his mother to do his ironing. But he does… ;);)
Petran07 - 回复
Good advice for a Scottish baby boomer who definitely DIDN'T vote for Brexit!
Linda Whyte - 回复
Thank you! Good advice for kid who has clothes worth 3 dollars and 1 moncler jacket worth 1000$!
_ Kløvedal - 回复
Most of these comments are just boomers and foreigners
Yes - 回复
Thank you this was good advice for someone looking for entertainment in the comments section.
Anyone interested in the google translation of the Chinese comment see below:
Thank you, this is a good suggestion for foreigners who speak Chinese. Even if they did not lose their marbles, they did not abstain, but there is still no clue.
Chris - 回复
oohhhhh really helpful thanks for this blog…. But I have a question did we follow these steps on leather jackets??
William James - 回复
I want to express my gratitude for sharing this helpful article that I personally think is very good. If you are fond of this type of jacket, I highly recommend you to check it out. Tops and bottoms online store.
david hudson - 回复
添加评论
浏览统计数据:
过去 24 小时: 59
过去 7 天: 462
过去 30 天: 2,202
总计 164,433
