跳转到主内容
加入维修社区 - 创建账户
How to Iron a Waterproof Jacket
你所需要的
  1. How to Iron a Waterproof Jacket, Prepare the jacket: 步骤 1 中的图像 1,1
    • Unzip your clean jacket and slide one half over your ironing board or towel-covered surface.
    • You only want to iron through one layer of the jacket at a time. Ironing through two layers can create creases in the bottom layer.
    • Flatten your jacket with your hands.
    添加评论
  2. How to Iron a Waterproof Jacket, Set up the iron: 步骤 2 中的图像 1,3 How to Iron a Waterproof Jacket, Set up the iron: 步骤 2 中的图像 2,3 How to Iron a Waterproof Jacket, Set up the iron: 步骤 2 中的图像 3,3
    • Set the iron to its lowest heat setting, below 230 °F.
    • Turn off the steam function. Steam can damage the fabric and the DWR coating. If you can't turn off the steam function on your iron, drain the water chamber completely.
    询问修复机器人
    添加评论
  3. How to Iron a Waterproof Jacket, Protect the jacket: 步骤 3 中的图像 1,2 How to Iron a Waterproof Jacket, Protect the jacket: 步骤 3 中的图像 2,2
    询问修复机器人
    添加评论
  4. How to Iron a Waterproof Jacket, Iron the jacket: 步骤 4 中的图像 1,2 How to Iron a Waterproof Jacket, Iron the jacket: 步骤 4 中的图像 2,2
    • Iron in one smooth stroke, running parallel to the zipper.
    • Only iron in one direction, don't go back and forth or you risk creating creases. Change directions only when you move to a new section of the jacket.
    • Don't press down. Let the heat and weight of the iron do the work.
    • Keep the iron moving continuously to avoid melting or burning the fabric.
    询问修复机器人
    添加评论
  5. How to Iron a Waterproof Jacket, Check your progress: 步骤 5 中的图像 1,3 How to Iron a Waterproof Jacket, Check your progress: 步骤 5 中的图像 2,3 How to Iron a Waterproof Jacket, Check your progress: 步骤 5 中的图像 3,3
    • Remove the towel and inspect the jacket.
    • If the fabric looks unchanged, increase the heat slightly and try again.
    • If the area looks smooth, move on to the next section.
    添加评论
    • To fully reactivate the DWR coating, heat must make contact with every part of the jacket. Go slowly and work in small, manageable sections to ensure even coverage.
    • Be extra careful around tight or curved areas like hoods, cuffs, and sleeves.
    • For the sleeves, slide a tailor’s ham, sleeve board, or folded towel inside the sleeve to separate the two sides.
    • Continue repositioning the jacket and repeating the ironing process until the entire surface has been treated.
    • Don't forget to turn off the iron when you're finished.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
24等其他人完成本指南。
Clara Redwood
于11/12/24注册
2,568 声望
创作了19篇指南
团队
Patagonia Patagonia 的会员
Community
9 名成员
创作了155篇指南
17指南评论
Thank you, good advice for younger generation who have clue.
keirakeith26 - 回复 分享
Thank you - good reminder for the older generation who have lost their marbles
Swag McYolo - 回复 分享
Thank you- good reminder for the baby boomer middle aged who voted for Brexit and haven't got a clue.
fixxysugar - 回复 分享
謝謝,對於說中文的外國人來說,這是一個很好的建議,即使他們沒有失去彈珠,他們也沒有投棄權,但仍然沒有任何線索。
艾爾伯特愛因斯坦 - 回复 分享
I hope the non-English comment is also in the same form as the first 3.
Eva - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 146
过去 30 天: 631
总计 203,668
