跳转到主内容
How to Intonate an Electric Guitar
你所需要的
  1. How to Intonate an Electric Guitar, How to Intonate an Electric Guitar: 步骤 1 中的图像 1,3 How to Intonate an Electric Guitar, How to Intonate an Electric Guitar: 步骤 1 中的图像 2,3 How to Intonate an Electric Guitar, How to Intonate an Electric Guitar: 步骤 1 中的图像 3,3
    • Attach your guitar to your chromatic tuner using a 1/4" guitar cable, ensuring cable is completely inserted.
    • Connect your chromatic tuner to a power source (if necessary) and power it on.
    • You will be leaving the guitar connected to the chromatic tuner for the duration of this guide.
  2. How to Intonate an Electric Guitar: 步骤 2 中的图像 1,2 How to Intonate an Electric Guitar: 步骤 2 中的图像 2,2
    • Tune your strings to your desired pitch by playing a note on an open string (not pressing down on any frets) and adjusting the tuning pegs.
    • For this guide the tuning used is E Standard. This tuning standard uses the following notes, from thickest string to thinnest: E A D G B E
  3. How to Intonate an Electric Guitar: 步骤 3 中的图像 1,2 How to Intonate an Electric Guitar: 步骤 3 中的图像 2,2
    • Check your sting intonation by pressing the string down at the 12th fret and playing a note.
    • This checks the tuning of your string at a higher octave, and is a good representation of your current intonation. You want this to be as close to in-tune as possible. The second picture of this step shows an extremely out-of-tune case.
  4. How to Intonate an Electric Guitar: 步骤 4 中的图像 1,1
    • Adjust your saddle position using a Philips-head screwdriver.
    • If your string pitch was flat, left of center, adjust the saddle towards the neck of the guitar (loosen). Otherwise, if the string pitch was sharp, adjust the saddle towards the bridge (tighten).
    • Make small adjustments, no more than a quarter to a half rotation at a time. Otherwise you run the risk of breaking a string.
  5. How to Intonate an Electric Guitar: 步骤 5 中的图像 1,3 How to Intonate an Electric Guitar: 步骤 5 中的图像 2,3 How to Intonate an Electric Guitar: 步骤 5 中的图像 3,3
    • Tune the adjusted string back to the proper pitch.
    • Depending on the amount of the adjustment, the pitch of the string can change quite a bit.
    • Once the string is in tune in the open (no frets being held), check the tuning at the 12th fret again.
  6. How to Intonate an Electric Guitar: 步骤 6 中的图像 1,2 How to Intonate an Electric Guitar: 步骤 6 中的图像 2,2
    • Repeat Steps 2 through 4 until the string is intonated.
    • This process can require multiple repetitions to complete depending on how "off" the intonation is.
  7. How to Intonate an Electric Guitar: 步骤 7 中的图像 1,3 How to Intonate an Electric Guitar: 步骤 7 中的图像 2,3 How to Intonate an Electric Guitar: 步骤 7 中的图像 3,3
    • Adjust the intonation of the remainder of the strings by repeating Steps 1-5 for each string.
    • The best way to do this is to follow the "6, 1, 5, 2, 4, 3" method. This is where you start with the outer strings and work inward. This method is illustrated in the provided images.
    • This method helps to preserve the tunings of the strings you are not adjusting when the guitar is equipped with a tremolo arm (Whammy Bar).
结论
After following this guide you should have a properly intonated electric guitar. No matter the note you should now be able to enjoy good tuning across all frets.
3等其他人完成本指南。
一条评论
I always find that either the G, or the B string, is, slightly, out of tune, when I'm through, while playing and open cord against a bar chord of the same pitch. I've heard that this is an inherent problem in guitar; is there any work around for that?
Dale Alan Bryant - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 363
