跳转到主内容
How to Install and Remove Tiles
你所需要的
  1. How to Install and Remove Tiles, Remove the Front Panel: 步骤 1 中的图像 1,3 How to Install and Remove Tiles, Remove the Front Panel: 步骤 1 中的图像 2,3 How to Install and Remove Tiles, Remove the Front Panel: 步骤 1 中的图像 3,3
    • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
  2. How to Install and Remove Tiles, Remove the Tiles: 步骤 2 中的图像 1,3 How to Install and Remove Tiles, Remove the Tiles: 步骤 2 中的图像 2,3 How to Install and Remove Tiles, Remove the Tiles: 步骤 2 中的图像 3,3
    • Use your fingers to push the bottom of the Tile up and off the front panel and release its clips.
    • Remove the Tile.
  3. How to Install and Remove Tiles: 步骤 3 中的图像 1,3 How to Install and Remove Tiles: 步骤 3 中的图像 2,3 How to Install and Remove Tiles: 步骤 3 中的图像 3,3
    • Repeat this procedure for the remaining tiles.
  4. How to Install and Remove Tiles, Install the Tiles: 步骤 4 中的图像 1,3 How to Install and Remove Tiles, Install the Tiles: 步骤 4 中的图像 2,3 How to Install and Remove Tiles, Install the Tiles: 步骤 4 中的图像 3,3
    • Tiles can be installed in any orientation, even the ones with graphics.
    • Lay a Tile over an open slot on your Front Panel.
    • Use your fingers to press the tile into the slot and engage the clips.
    • You'll hear and feel an audible "click" when the clips engage.
  5. How to Install and Remove Tiles: 步骤 5 中的图像 1,3 How to Install and Remove Tiles: 步骤 5 中的图像 2,3 How to Install and Remove Tiles: 步骤 5 中的图像 3,3
    • Install the remaining Tiles.
  6. How to Install and Remove Tiles: 步骤 6 中的图像 1,3 How to Install and Remove Tiles: 步骤 6 中的图像 2,3 How to Install and Remove Tiles: 步骤 6 中的图像 3,3
    • Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
    • Press the Front Panel flat to the chassis and let it align to the magnets.
结论
If you need help, contact Framework support.
Alex Diaz-Kokaisl
于01/16/22注册
213,259 声望
创作了1,040篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 180
