跳转到主内容
How to Install a Fifth String Shubb Banjo Capo
你所需要的
  1. How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: 步骤 1 中的图像 1,3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: 步骤 1 中的图像 2,3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: 步骤 1 中的图像 3,3
    • Line the capo up along the fifth string side of the fretboard as shown.
    • Line the capo screw holes up about 12 mm from the fifth fret bar and about 4 mm from the face of the fret.
    • Be careful not to line the capo screw holes up directly below a fret bar or directly on top of a fret marker.
  2. How to Install a Fifth String Shubb Banjo Capo: 步骤 2 中的图像 1,1
    • Use the marker to mark where the screws should go.
  3. How to Install a Fifth String Shubb Banjo Capo: 步骤 3 中的图像 1,1
    • Use the drill to drill both holes for the two screws.
    • The holes should be drilled about 1 cm deep
    • You may need to borrow an extra pair of hands to help you stabilize the banjo while you perform this step.
  4. How to Install a Fifth String Shubb Banjo Capo: 步骤 4 中的图像 1,2 How to Install a Fifth String Shubb Banjo Capo: 步骤 4 中的图像 2,2
    • Use the flat head screw driver to insert and tighten the screws.
  5. How to Install a Fifth String Shubb Banjo Capo: 步骤 5 中的图像 1,3 How to Install a Fifth String Shubb Banjo Capo: 步骤 5 中的图像 2,3 How to Install a Fifth String Shubb Banjo Capo: 步骤 5 中的图像 3,3
    • To use the capo, slide the capo finger down to the desired fret.
    • Then, tighten the spring knob.
结论
For more information check out the Shubb fifth string capo website at: http://www.shubb.com/fs/index.html
6等其他人完成本指南。
Sara Wier
于02/24/15注册
263 声望
撰写一个指南
团队
Cal Poly, Team 23-4, Green Winter 2015 Cal Poly, Team 23-4, Green Winter 2015 的会员
CPSU-GREEN-W15S23G4
7 名成员
创作了15篇指南
1指南评论
thank you. Now, I know how to do and i décide to buy a shubb and to install it
Jean-Denis Del - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 44
总计 7,875
