简介
How To Flash TWRP recovery on rooted Android devices via Flashify APK
视频概述
  1. Do you already own a rooted Android device and looking for an easy and successful method to flash TWRP 3.0.0 on your rooted Android device. If so, keep reading would not be a time waste. The TWRP custom recovery is a useful recovery which helps Android users to execute processes like rooting, flashing Custom ROMs/Xposed Installer/MODs and many more
    • Do you already own a rooted Android device and looking for an easy and successful method to flash TWRP 3.0.0 on your rooted Android device. If so, keep reading would not be a time waste. The TWRP custom recovery is a useful recovery which helps Android users to execute processes like rooting, flashing Custom ROMs/Xposed Installer/MODs and many more
    • In here you can learn how to flash TWRP 3.0.0 using Flashify on Rooted Android devices.
    添加评论
    • Flashify APK is a specially designed application which can be only installed on Rooted Android devices. It allows users to flash what they want on their rooted android devices very quickly and simply. The latest version of Flashify APK is Flashify APK 1.9.2 and works on Android KitKat and above versions
    • Previously, the app was designed targeting specific Nexus device models and finally, it was executed to work with any Android device which uses Android KitKat OS or higher.
    添加评论
    • Flash boot and recovery .img without having recovery
    • Keep records of recently flashed files
    • Flash zip files while giving an option to wipe cache, dalvik and data when using either TWRP or Philz recovery
    • Backup/Restore kernel and recovery using Sdcard or cloud for future needs
    • Has the ability to flash from any where such as File Explorer or Email app
    • Download and flash any recovery such as CWM, Philz, and TWRP etc.
    • Synchronisation backups automatically between smart devices and desktops
    • Flash multiple files and make your flash queue
    添加评论
  2. 传播 Fixmas 欢乐
    Get $12 off your purchase of $50 or more with code FIXMAS12
    传播 Fixmas 欢乐
    • Rooted Android device with 4.0 KitKat or upper version
    • Wi-Fi or a strong network connection
    • 15MB of disk space or higher
    • 1GB RAM or higher
    添加评论
  3. 添加评论
    • Download Flashify APK latest version and install
    • Next, download the TWRP 3.0.0 image file
    • Be cautious to select the recommended image according to your device
    • Now, launch Flashify APK and grant root permission
    • Click on the recovery image and choose recovery.img file or twrp.img file
    • Finally click OK to flash TWRP 3.0.0 recovery on your Android device
    • Note: Always have a full backup of the device before proceeding
    添加评论
    • Launch Flashify APK
    • Select Backup/Restore option
    • Next, select "Backup current kernel" or "Backup current recovery" according to your preference
    添加评论
    • All the thanks and credits go to Christian Göllner who is a software engineer and a senior member of XDA developer for designing and distributing the Flashify APK for free
    添加评论
结论
另外一个人完成了本指南。
Sally Denton
于2018年11月04日注册
355 信誉积分
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 10
过去的30天: 34
总计 65
