跳转到主内容
加入维修社区 - 创建账户
How to Install Shoulder Buttons in Your Game Boy Advance SP
    1. How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the hinge pin: 步骤 1 中的图像 1,2 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the hinge pin: 步骤 1 中的图像 2,2
      • If the hinge pin fell out when removing the shoulder button, put it back into place.
      询问修复机器人
      添加评论
    2. How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the spring: 步骤 2 中的图像 1,3 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the spring: 步骤 2 中的图像 2,3 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the spring: 步骤 2 中的图像 3,3
      • The two springs are not interchangeable. It should be clear if you're trying to install the wrong spring, as it won't fit correctly in the button.
      • Slide the spring into the shoulder button so the bent arm goes into the cutout on the inside edge.
      询问修复机器人
      添加评论
    3. How to Install Shoulder Buttons in Your Game Boy Advance SP, Put the shoulder button in place: 步骤 3 中的图像 1,3 How to Install Shoulder Buttons in Your Game Boy Advance SP, Put the shoulder button in place: 步骤 3 中的图像 2,3 How to Install Shoulder Buttons in Your Game Boy Advance SP, Put the shoulder button in place: 步骤 3 中的图像 3,3
      • When installing the button, make sure it's oriented so the spring's straight arm is on top.
      • Use your fingers to hold the spring in place and slide the button over the hinge pin and into its recess.
      询问修复机器人
      添加评论
    4. How to Install Shoulder Buttons in Your Game Boy Advance SP, Push the spring arm into place: 步骤 4 中的图像 1,2 How to Install Shoulder Buttons in Your Game Boy Advance SP, Push the spring arm into place: 步骤 4 中的图像 2,2
      • Use your finger, a spudger, or a pair of tweezers to rotate the spring arm into its clip.
      询问修复机器人
      添加评论
    5. How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the other shoulder button: 步骤 5 中的图像 1,3 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the other shoulder button: 步骤 5 中的图像 2,3 How to Install Shoulder Buttons in Your Game Boy Advance SP, Install the other shoulder button: 步骤 5 中的图像 3,3
      • Repeat the process to install the other shoulder button.
      询问修复机器人
      添加评论
结论
Return to your original repair guide and continue with reassembly.
取消:我没有完成这个指南。
2等其他人完成本指南。
Spencer Day
于09/14/22注册
199,979 声望
创作了1,243篇指南
1指南评论
Thanks for adding this small guide, linked from the 'How to Reshell' guide. The springs of my shoulder buttons fell out during disassembly and this made it so much easier and less stressful, knowing I was doing it right. Everything works perfect again, including a stuck button (I had to replace the rubber pad)
CircuitBenT - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 54
过去 30 天: 246
总计 1,847
