跳转到主内容
How to Install Kali Linux onto a Virtual Machine
  1. How to Install Kali Linux onto a Virtual Machine, Install your VMware software: 步骤 1 中的图像 1,1
    • Navigate to VMware Workstation Download Center
    • Based on your system requirements, click on Go to Downloads for VMware Workstation for either Windows or Linux.
    • Click Download Now, and if prompted log into your Customer Connect profile. If you don't have one you will need to create one.
    • Download Kali Linux from the official download page, and select the build the best suits your needs.
    • Check the integrity of the image you downloaded by comparing the SHA-256 fingerprint of the file and compare it to the hexadecimal numbers on the downloads page.
  2. How to Install Kali Linux onto a Virtual Machine, Launch your new virtual machine: 步骤 3 中的图像 1,1
    • On the VMware Workstation homepage, click on create a new virtual machine
    • Choose the Kali Linux ISO file, and select the guest operating system.
    • When Configuring your virtual machine, be sure the VM meets the requirements
    • Start your newly created virtual machine by selecting the Kali Linux VM, and clicking on the green Power On button
  3. How to Install Kali Linux onto a Virtual Machine, Installation Procedure: 步骤 4 中的图像 1,1
    • Once the VM is powered on, you will be prompted to select your preferred installation mode. Choose the graphical installation and continue.
    • The next couple off screens will ask you for basic locale information, keyboard layout, network information, and system password etc.
  4. How to Install Kali Linux onto a Virtual Machine, Disk partitioning: 步骤 5 中的图像 1,3 How to Install Kali Linux onto a Virtual Machine, Disk partitioning: 步骤 5 中的图像 2,3 How to Install Kali Linux onto a Virtual Machine, Disk partitioning: 步骤 5 中的图像 3,3
    • Once your basic system configuration is set, the installer will ask you to choose a partitioning option for your virtual disk. Choose Guided - Use Entire Disk for the easiest option.
    • Select the partitioning disk and hit continue.
    • It is highly recommended that you choose the All files in one partition option if you are a new user.
    • Confirm all the changes that are made to the changes to the disk on the host machine.
    • This will Erase Data on the Virtual Disk. This shouldn't effect data on the host machine, but it is worth noting.
  5. How to Install Kali Linux onto a Virtual Machine, Configure the Package Manager: 步骤 6 中的图像 1,1
    • Once the necessary files are installed the installer will ask if you want to set up a Network Mirror.
    • Enabling this function will allow you to use the Kali repositories, and is highly recommended if you want to obtain future pieces of software and updates.
  6. How to Install Kali Linux onto a Virtual Machine, Install GRUB boot loader: 步骤 7 中的图像 1,1
    • Once you have selected your package manager option you will be asked to install the GRUB boot loader.
    • Select Yes and pick the device to write the necessary boot loader information onto the information to the virtual disk
  7. How to Install Kali Linux onto a Virtual Machine, Finished: 步骤 8 中的图像 1,1
    • Once the installer finishes installing the GRUB to the disk, click on Continue to finish the installation process.
结论
Congratulations! You have installed Kali Linux, and are now ready to begin your journey into exploring Kali Linux. But, the most important thing you should take away from this guide is to remember to use this information responsibly. Obtaining unauthorized access to another's computer system or systems is illegal under the Computer Fraud & Abuse Act.
Please use the knowledge gained from this guide responsibly.
9等其他人完成本指南。
Jacob Mehnert
于10/18/21注册
44,284 声望
创作了51篇指南
团队
iFanatics iFanatics 的会员
Community
63 名成员
创作了219篇指南
3指南评论
Bonsoir a vous .
J remercie vraiment celui qui a mi les différents etapes pour pouvoir installer kali linux sans avoir de compétence avance en informatique.
J suis encore débutant mais j sens k l apprentissage pour devenir un bon hacker sera possible grâce a vous différents guides et conseils.
Merci beaucoup d avance pour tout.
BEFO l' orchidée - 回复
Bonne soirée à toi également,
Je suis heureux que vous ayez trouvé mon guide utile. Cependant, je veux que vous gardiez à l'esprit que ce guide est conçu à des fins éducatives et ne doit être utilisé que pour tester votre propre réseau. Je ne sais pas exactement comment c'est pour les autres pays, je sais qu'aux États-Unis, le piratage n'est autorisé que dans des circonstances spécifiques. Je vous recommande vivement de rechercher des informations sur les lois sur la cybersécurité de votre pays et sur la manière dont elles sont interprétées.
J'espère que cela vous sera utile dans vos efforts
Jacob Mehnert -
je salut vivement l'éthique de communauté pédagogique des guides d'utilisation de Kali Linux qui est pour moi une révolution de la technologie Futur ...
moustapha mohamed - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 52
过去 30 天: 311
总计 59,769
