跳转到主内容
How to Install Handlebar Tape
你所需要的
  1. How to Install Handlebar Tape, How to Install Handlebar Tape: 步骤 1 中的图像 1,2 How to Install Handlebar Tape, How to Install Handlebar Tape: 步骤 1 中的图像 2,2
    • Flip the hood of the brake lever upwards.
  2. How to Install Handlebar Tape: 步骤 2 中的图像 1,3 How to Install Handlebar Tape: 步骤 2 中的图像 2,3 How to Install Handlebar Tape: 步骤 2 中的图像 3,3
    • Peel off the adhesive covering from the back of the bar tape.
    • Place one end of the bar tape around the handlebar, making sure to leave a half inch extended past the end of the handlebar.
    • Begin tightly wrapping the bar tape clockwise around the handlebar so that the bar tape overlaps itself slightly.
  3. How to Install Handlebar Tape: 步骤 3 中的图像 1,2 How to Install Handlebar Tape: 步骤 3 中的图像 2,2
    • After a few wraps, tuck the extra bar tape into the end of the handlebar and firmly push in the bar end plug.
  4. How to Install Handlebar Tape: 步骤 4 中的图像 1,2 How to Install Handlebar Tape: 步骤 4 中的图像 2,2
    • Continue to tightly wrap the bar tape around the bar as evenly as possible.
    • Make sure the adhesive on the back of the bar tape is making contact with the metal handlebar.
  5. How to Install Handlebar Tape: 步骤 5 中的图像 1,3 How to Install Handlebar Tape: 步骤 5 中的图像 2,3 How to Install Handlebar Tape: 步骤 5 中的图像 3,3
    • Take the extra piece of bar tape provided and cut it to fit the back of the brake lever.
  6. How to Install Handlebar Tape: 步骤 6 中的图像 1,3 How to Install Handlebar Tape: 步骤 6 中的图像 2,3 How to Install Handlebar Tape: 步骤 6 中的图像 3,3
    • Continue wrapping over lever.
    • Keep in mind the tightness and evenness of space between each wrap as you continue.
  7. How to Install Handlebar Tape: 步骤 7 中的图像 1,2 How to Install Handlebar Tape: 步骤 7 中的图像 2,2
    • Flip the break lever hood back down and continue.
  8. How to Install Handlebar Tape: 步骤 8 中的图像 1,2 How to Install Handlebar Tape: 步骤 8 中的图像 2,2
    • Stop wrapping about 2 inches from stem.
  9. How to Install Handlebar Tape: 步骤 9 中的图像 1,3 How to Install Handlebar Tape: 步骤 9 中的图像 2,3 How to Install Handlebar Tape: 步骤 9 中的图像 3,3
    • Cut the bar tape diagonally at an approximately 60 degree angle.
  10. How to Install Handlebar Tape: 步骤 10 中的图像 1,1
    • Finish the wrap.
    • The cut should make the end of the bar tape a straight line.
  11. How to Install Handlebar Tape: 步骤 11 中的图像 1,3 How to Install Handlebar Tape: 步骤 11 中的图像 2,3 How to Install Handlebar Tape: 步骤 11 中的图像 3,3
    • Use the electrical tape provided to tightly secure the end of the wrap.
  12. How to Install Handlebar Tape: 步骤 12 中的图像 1,3 How to Install Handlebar Tape: 步骤 12 中的图像 2,3 How to Install Handlebar Tape: 步骤 12 中的图像 3,3
    • Press down on electrical tape to secure it.
  13. How to Install Handlebar Tape: 步骤 13 中的图像 1,3 How to Install Handlebar Tape: 步骤 13 中的图像 2,3 How to Install Handlebar Tape: 步骤 13 中的图像 3,3
    • Repeat steps 1-12 on the other side, now wrapping counterclockwise.
终点
另外一个人完成了本指南。
Elizabeth Hall
于04/28/17注册
131 声望
撰写一个指南
团队
UC Davis, Team S2-G7, Cole Spring 2017 UC Davis, Team S2-G7, Cole Spring 2017 的会员
UCD-COLE-S17S2G7
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 4,290
