跳转到主内容
How to Install Extra RAM in a Samsung 14'' Essential Notebook
你所需要的
  1. How to Install Extra RAM in a Samsung 14'' Essential Notebook, RAM: 步骤 1 中的图像 1,2 How to Install Extra RAM in a Samsung 14'' Essential Notebook, RAM: 步骤 1 中的图像 2,2
    • Remove the battery.
    • Use a Phillips #0 screwdriver to remove the single 4 mm screw securing the memory compartment cover.
  2. How to Install Extra RAM in a Samsung 14'' Essential Notebook: 步骤 2 中的图像 1,1
    • Remove the memory compartment cover from the laptop by gently pushing it up until it's fully detached, then lift it up and off.
  3. How to Install Extra RAM in a Samsung 14'' Essential Notebook: 步骤 3 中的图像 1,1
    • Make sure that your laptop has at least one memory slot available. In this case, the available slot is the top one. This is the slot in which we will insert our new memory.
    • RAM cards for laptops are different than RAM cards for PC. They are smaller, and not all of them will work for your laptop. For example, DDR4 RAMs won't work if your laptop supports DDR3 components. In this case, we're using a DDR3 4GB RAM card.
  4. How to Install Extra RAM in a Samsung 14'' Essential Notebook: 步骤 4 中的图像 1,3 How to Install Extra RAM in a Samsung 14'' Essential Notebook: 步骤 4 中的图像 2,3 How to Install Extra RAM in a Samsung 14'' Essential Notebook: 步骤 4 中的图像 3,3
    • Carefully insert the new RAM card into the free slot, then push it down slowly until it clicks into place.
  5. How to Install Extra RAM in a Samsung 14'' Essential Notebook: 步骤 5 中的图像 1,2 How to Install Extra RAM in a Samsung 14'' Essential Notebook: 步骤 5 中的图像 2,2
    • Replace the memory compartment cover.
    • Tighten the single Phillips #0 screw to secure the memory compartment cover.
    • It is important that this compartment is completely secured to avoid any potential damage to the internal components of your computer.
  6. How to Install Extra RAM in a Samsung 14'' Essential Notebook: 步骤 6 中的图像 1,3 How to Install Extra RAM in a Samsung 14'' Essential Notebook: 步骤 6 中的图像 2,3 How to Install Extra RAM in a Samsung 14'' Essential Notebook: 步骤 6 中的图像 3,3
    • To ensure that the RAM is properly installed, turn on your computer and open the system settings.
    • Go to "System> About," and look for the "Device Specifications" section.
    • In the “Installed RAM” section, make sure it displays the correct amount of RAM.
    • In this case, we originally had 4GB RAM on our computer. By adding a new 4GB RAM card, we now have 8GB installed, improving the performance of our computer.
结论
Enjoy your laptop's improved performance!
Naqeeb Bhatti
于07/06/22注册
133 声望
撰写一个指南
团队
York University, Team M-3, Allen Summer 2022 York University, Team M-3, Allen Summer 2022 的会员
YORK-ALLEN-SU22SMG3
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 193
