跳转到主内容
How to Hook up Front Panel Connectors to an ATX Motherboard
你所需要的
  1. How to Hook up Front Panel Connectors to an ATX Motherboard, How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 1 中的图像 1,3 How to Hook up Front Panel Connectors to an ATX Motherboard, How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 1 中的图像 2,3 How to Hook up Front Panel Connectors to an ATX Motherboard, How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 1 中的图像 3,3
    • Lay your PC on its side and unscrew the side panel thumb screws. (Open your PC case)
    • For some computer cases you may need a screw driver to remove actual screws.
  2. How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 2 中的图像 1,2 How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 2 中的图像 2,2
    • Once the screws are removed lift off the side panel to expose the motherboard and internal cables.
    • Locate where the front panel pins are.
  3. How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 3 中的图像 1,3 How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 3 中的图像 2,3 How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 3 中的图像 3,3
    • Plug the cable marked Reset SW into the motherboard. This will allow your reset button to actually work.
  4. How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 4 中的图像 1,3 How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 4 中的图像 2,3 How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 4 中的图像 3,3
    • Plug the Power SW cable in above the Reset SW on the motherboard. This will allow you to turn on your computer with the power button on the front of your PC case.
  5. How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 5 中的图像 1,3 How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 5 中的图像 2,3 How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 5 中的图像 3,3
    • Plug the Power Led + into the top left prong. Positive goes on the left prong.
  6. How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 6 中的图像 1,3 How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 6 中的图像 2,3 How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 6 中的图像 3,3
    • Connect the Power Led - cable to the prong on the right.
    • This is the final cable structure.
  7. How to Hook up Front Panel Connectors to an ATX Motherboard: 步骤 7 中的图像 1,1
    • Power LED
    • Power Switch
    • Reset Switch
结论
To reassemble your device, follow the instructions, steps 1 and 2, in reverse order.
11等其他人完成本指南。
Nathan Carini
于03/26/21注册
357 声望
撰写一个指南
团队
2指南评论
Petite précision :
Les broches sur lesquels il faut brancher les connecteurs des différents éléments du boitier sont indiquées dans la notice de la carte mère (button power, LEDs, etc.). L’emplacement et l’ordre de branchement des différents éléments du boitier est susceptible de varier selon le modèle de la carte mère.
Cela concerne aussi le buzzer si vous en avez un.
Brendan - 回复
Bonjour Tout le monde*
Je suis d'accord avec vous , mais dans quel sens mettre sur le boitier de démarrage vous avez power reset led 2 prise usb , quand j'ai enlevé du boitier je n'ai marquer les metttre ou
Je vous remercie d'avance.
KIEFFER RENE - 回复
添加评论
浏览统计数据:
过去 24 小时: 70
过去 7 天: 481
过去 30 天: 2,269
总计 132,623
