跳转到主内容
How to Hem a Dress
你所需要的
  1. How to Hem a Dress, How to Hem a Dress: 步骤 1 中的图像 1,2 How to Hem a Dress, How to Hem a Dress: 步骤 1 中的图像 2,2
    • Begin with dress that is too long for the desired fit or style.
  2. How to Hem a Dress: 步骤 2 中的图像 1,1
    • Lay the dress out flat, aligning the bottom seams.
    • Make sure any under layers are out of the way.
  3. How to Hem a Dress: 步骤 3 中的图像 1,1
    • With a ruler, measure the amount you want the dress shortened.
    • After deciding, subtract 1" (25.4mm) from the seam allowance
    • (Ex: You want 3" (76.2mm) off, so you would measure 2'' (50.8mm) from the bottom of the fabric.)
  4. How to Hem a Dress: 步骤 4 中的图像 1,1
    • Use chalk or pen to mark the measurement.
    • Make small dashed marks around the entire dress to ensure a consistent measurement.
  5. How to Hem a Dress: 步骤 5 中的图像 1,1
    • Iron the dress flat.
  6. How to Hem a Dress: 步骤 6 中的图像 1,1
    • Use scissors to cut vertically from the bottom seam to where you marked your measurement.
  7. How to Hem a Dress: 步骤 7 中的图像 1,1
    • Then turn the scissors 90 degrees and begin cutting along the dashed lines you made in Step 4.
  8. How to Hem a Dress: 步骤 8 中的图像 1,1
    • Then, again with the ruler and chalk measure 1/2'' (12.7 mm) from the raw edge of the fabric.
  9. How to Hem a Dress: 步骤 9 中的图像 1,2 How to Hem a Dress: 步骤 9 中的图像 2,2
    • Fold along the measurement you just made and iron it flat.
  10. How to Hem a Dress: 步骤 10 中的图像 1,2 How to Hem a Dress: 步骤 10 中的图像 2,2
    • Then fold again, one more time at 1/2''.
    • Lastly iron flat.
  11. How to Hem a Dress: 步骤 11 中的图像 1,2 How to Hem a Dress: 步骤 11 中的图像 2,2
    • Pin the fold in place.
    • Be careful when you pin.
  12. How to Hem a Dress: 步骤 12 中的图像 1,1
    • If using a sewing machine, place it under the foot of the sewing machine.
    • Sew around the entire circumference of the dress.
    • Be careful when using a sewing machine.
  13. How to Hem a Dress: 步骤 13 中的图像 1,3 How to Hem a Dress: 步骤 13 中的图像 2,3 How to Hem a Dress: 步骤 13 中的图像 3,3
    • Cut the threads and you're done!
结论
Juliette Price
于02/02/24注册
217 声望
撰写一个指南
团队
UC Davis, Team 3-5, Andersen Winter 2024 UC Davis, Team 3-5, Andersen Winter 2024 的会员
UCD-ANDERSEN-W24S3G5
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 109
