跳转到主内容
How to Hem Sweatpants
你所需要的
  1. How to Hem Sweatpants, How to Hem Sweatpants: 步骤 1 中的图像 1,2 How to Hem Sweatpants, How to Hem Sweatpants: 步骤 1 中的图像 2,2
    • Use the seam ripper to remove the seams along the hem of the bottom of the pants.
  2. How to Hem Sweatpants: 步骤 2 中的图像 1,1
    • Remove the elastic band from the pants. Keep the elastic for later.
  3. How to Hem Sweatpants: 步骤 3 中的图像 1,1
    • Place pins where you want the pants to end.
  4. How to Hem Sweatpants: 步骤 4 中的图像 1,3 How to Hem Sweatpants: 步骤 4 中的图像 2,3 How to Hem Sweatpants: 步骤 4 中的图像 3,3
    • Measure the length of the cuff.
    • Measure how long the pants need to be cut.
    • Keeping in mind a small length below the pins for the new cuff, mark where you want to cut with your washable marker.
  5. How to Hem Sweatpants: 步骤 5 中的图像 1,1
    • Using the fabric scissors, cut along the line you marked, making sure to keep a straight and steady line.
  6. How to Hem Sweatpants: 步骤 6 中的图像 1,1
    • Fold the new end of the pants outward, at a minimum of double the length of the elastic band.
  7. How to Hem Sweatpants: 步骤 7 中的图像 1,2 How to Hem Sweatpants: 步骤 7 中的图像 2,2
    • Place the elastic band on top of the fold from the previous step.
    • Place the top of the elastic along the pin line.
    • Using the needle and thread, sew both ends of the elastic band to the seam running vertically up and down the pant leg.
  8. How to Hem Sweatpants: 步骤 8 中的图像 1,2 How to Hem Sweatpants: 步骤 8 中的图像 2,2
    • Fold the top of the folded fabric section back over the elastic, using the pins as the top line.
    • Place pins along the bottom of the new fold to keep the fabric in place.
  9. How to Hem Sweatpants: 步骤 9 中的图像 1,3 How to Hem Sweatpants: 步骤 9 中的图像 2,3 How to Hem Sweatpants: 步骤 9 中的图像 3,3
    • Sew a new hem along the line created by the new pins. You can either hand-sew or use a sewing machine.
    • Sew ONLY along the new pins placed in the previous step. Do not sew along the first row of pins created at the beginning.
    • Once the sewing is complete, remove all the pins and undo the first fold.
    • The last photo provides a sample of the finished product.
终点
另外一个人完成了本指南。
1指南评论
Thanks very much for this tutorial because at 5’ I have to shorten everything. Now I can alter sweatpants that are made for 6’ tall people.
Ruthann45 - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 52
过去 30 天: 222
总计 14,146
