跳转到主内容
How to Hem Pants by Hand-Sewing
你所需要的
  1. How to Hem Pants by Hand-Sewing, How to Hem Pants by Hand-Sewing: 步骤 1 中的图像 1,1
    • Wear the pants and fold the hem up until you get your desired length.
  2. How to Hem Pants by Hand-Sewing: 步骤 2 中的图像 1,1
    • Remove the pants, making sure that the folded hem remains fixed.
    • Lay the pants down on a table and measure the length from the original hem to the folded edge.
    • Make sure to take note of all of your measurements.
  3. How to Hem Pants by Hand-Sewing: 步骤 3 中的图像 1,1
    • Turn the pants inside out, and unfold the folded edge.
    • Starting from the original hem, measure out the length of what will be your new hem.
    • The length you will need for this step would be the length you measured out from the previous step.
    • Using your fabric marker, draw a line marking where your new hem would be.
  4. How to Hem Pants by Hand-Sewing: 步骤 4 中的图像 1,1
    • Starting from the line you just created, measure out 1 inch and mark with a line.
  5. How to Hem Pants by Hand-Sewing: 步骤 5 中的图像 1,1
    • Using the 1 inch line as your guide, cut off the extra fabric.
  6. How to Hem Pants by Hand-Sewing: 步骤 6 中的图像 1,2 How to Hem Pants by Hand-Sewing: 步骤 6 中的图像 2,2
    • Fold the raw edge up to the new hem line.
    • Fold it again along the new hem line, so that the raw edge is now inside the fold.
  7. How to Hem Pants by Hand-Sewing: 步骤 7 中的图像 1,2 How to Hem Pants by Hand-Sewing: 步骤 7 中的图像 2,2
    • Place a sewing pin parallel to the fold to make sure that the fold stays in place.
    • Fold and pin all the way around to create your new hem.
  8. How to Hem Pants by Hand-Sewing: 步骤 8 中的图像 1,1
    • Have your needle threaded and ready to go.
    • Sew the fold close to create a new hem; try to keep your stitches small and even.
    • White thread was used instead of black to make the stitches more evident in the pictures.
  9. How to Hem Pants by Hand-Sewing: 步骤 9 中的图像 1,3 How to Hem Pants by Hand-Sewing: 步骤 9 中的图像 2,3 How to Hem Pants by Hand-Sewing: 步骤 9 中的图像 3,3
    • Once you're done stitching, tie off the thread by creating a knot towards the end of the string.
    • Cut off the excess string above the knot.
    • Remove all of the sewing pins.
    • Repeat steps 3 to 8 for the other pant leg using the same measurements, and then you're officially done!
结论
18等其他人完成本指南。
Irish Pellas
于09/29/15注册
709 声望
撰写一个指南
团队
Cal Poly, Team 15-5, Green Fall 2015 Cal Poly, Team 15-5, Green Fall 2015 的会员
CPSU-GREEN-F15S15G5
4 名成员
创作了14篇指南
一条评论
Thank you for this guide! The only thing I am uncertain about is how determine a good length for the pants. I read in another guide that it would be good to measure with shoes on. So that the pant leg grazes the shoe. Can you recommend the same?
Christin Kalina - 回复
添加评论
浏览统计数据:
过去 24 小时: 34
过去 7 天: 200
过去 30 天: 1,014
总计 141,303
