跳转到主内容
How to Hand Sew Patches Onto a Garment
你所需要的
  1. How to Hand Sew Patches Onto a Garment, How to Hand Sew Patches Onto a Garment: 步骤 1 中的图像 1,1
    • Place the cardboard separator in between the layers of your chosen garment.
    • This helps to avoid stitching both sides of the garment together.
  2. How to Hand Sew Patches Onto a Garment: 步骤 2 中的图像 1,1
    • Choose a color of thread that matches or contrasts with the color of your patch.
  3. How to Hand Sew Patches Onto a Garment: 步骤 3 中的图像 1,2 How to Hand Sew Patches Onto a Garment: 步骤 3 中的图像 2,2
    • Choose where you’d like the patch to sit on the garment.
    • To help with stability, use pins and iron the garment to maintain the position of the patch.
  4. How to Hand Sew Patches Onto a Garment: 步骤 4 中的图像 1,2 How to Hand Sew Patches Onto a Garment: 步骤 4 中的图像 2,2
    • Push the thread through the eye of the needle.
    • To prevent fraying, twist the ends of the thread to tighten it.
  5. How to Hand Sew Patches Onto a Garment: 步骤 5 中的图像 1,3 How to Hand Sew Patches Onto a Garment: 步骤 5 中的图像 2,3 How to Hand Sew Patches Onto a Garment: 步骤 5 中的图像 3,3
    • Insert the needle through the backside of the shirt and patch.
    • Pull the needle until the thread is taut.
    • Insert the needle through the outside of the shirt and patch, at the length you’d like your stitch to be.
    • Pull the needle again until the thread is taut.
  6. How to Hand Sew Patches Onto a Garment: 步骤 6 中的图像 1,3 How to Hand Sew Patches Onto a Garment: 步骤 6 中的图像 2,3 How to Hand Sew Patches Onto a Garment: 步骤 6 中的图像 3,3
    • On the backside, insert the needle at a similar distance to the previous stitch, away from the previous stitch.
    • Insert the needle at the end of the previous stitch; this will be stitching backwards.
  7. How to Hand Sew Patches Onto a Garment: 步骤 7 中的图像 1,3 How to Hand Sew Patches Onto a Garment: 步骤 7 中的图像 2,3 How to Hand Sew Patches Onto a Garment: 步骤 7 中的图像 3,3
    • Lace the needle through the extra fabric of the shirt that is covered by the patch.
    • Hold both ends of your thread and rotate it around the needle twice.
    • Create a loop using the thread and pull your needle through the loop.
    • Pull until the knot has formed (no extra thread is leftover).
    • Cut the thread with 1-2 inches to spare.
  8. How to Hand Sew Patches Onto a Garment: 步骤 8 中的图像 1,1
    • Finished Product!
终点
另外一个人完成了本指南。
Shannon Ikemiya
于04/24/24注册
178 声望
撰写一个指南
团队
UC Davis, Team 2-1, Whithaus Spring 2024 UC Davis, Team 2-1, Whithaus Spring 2024 的会员
UCD-WHITHAUS-S24S2G1
4 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 57
总计 418
