当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
在这个步骤中使用的工具:Desoldering Pump$3.99-
With the help of a syringe or anything that can suck liquid, clean the remaining ink from the tube.
I also went ahead and cleared the pad from as much ink as I could, it can buy you a bit more life span to the pad if you are in a hurry to print and not have the replacement items for this hack.
这个步骤还没有翻译 帮忙翻译一下
Put a connector on the end of the aquarium tube and connect it to the top of the bottle. Make sure that there is no chance of spilling or else you will have a big black spot of ink under your printer.
I inserted another connector on the top side of the bottle to release any pressure created by the ink coming in and the air in the bottle.
17等其他人完成本指南。
13条评论
I have the same problem. I will try that step. Good instructions. Thank you.
Thanks for this! =) God bless!
i need the ressetter for an epson l310
will this work on L220?
anyone have try this?
eufrasiaaa - 回复
