跳转到主内容
How to Format a drive in Windows 7-11
你所需要的
  1. How to Format a drive in Windows 7-11, Open File Explorer: 步骤 1 中的图像 1,1
    • Open File Explorer.
    • You can do that from either of the red highlighted spots, or search for "File Explorer."
  2. How to Format a drive in Windows 7-11, Open the Format Menu: 步骤 2 中的图像 1,2 How to Format a drive in Windows 7-11, Open the Format Menu: 步骤 2 中的图像 2,2
    • Right-Click on the drive you want to format, and click format
    • This is what should pop up.
  3. How to Format a drive in Windows 7-11, Format your drive: 步骤 3 中的图像 1,1
    • If you will be using the drive for Windows, format it as NTFS. If you need a multi-OS drive, exFAT or FAT32 is recommended.
    • FAT32 has a 4GB limit on single file size.
    • Use default allocation size.
    • If you want to rename your drive, put the new name here.
    • Start the format. When It's done, you can close all the windows, and you are done.
终点
6等其他人完成本指南。
George A.
于12/07/16注册
22,416 声望
创作了4篇指南
团队
Community Protectors Community Protectors 的会员
Community
19 名成员
创作了26篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 54
总计 3,741
