跳转到主内容
How to Format a drive in Windows 7-10
你所需要的
  1. How to Format a drive in Windows 7-10, Open File Explorer: 步骤 1 中的图像 1,1
    • Open File Explorer.
    • You can do that from either of the red highlighted spots, or search for "File Explorer."
  2. How to Format a drive in Windows 7-10, Open the Format Menu: 步骤 2 中的图像 1,2 How to Format a drive in Windows 7-10, Open the Format Menu: 步骤 2 中的图像 2,2
    • Right-Click on the drive you want to format, and click format
    • This is what should pop up.
  3. How to Format a drive in Windows 7-10, Format your drive: 步骤 3 中的图像 1,1
    • if you will be using the drive for Windows, format it as NTFS. If you need a multi-OS drive, exFAT or FAT32 is recommended. However, keep in mind FAT32 has a 4GB limit on files.
    • Use default allocation size.
    • If you want to rename your drive put the new name here.
    • Start the format. When It's done, you can close all the windows, and you are done.
终点
6等其他人完成本指南。
George A.
于12/07/16注册
21,996 声望
创作了4篇指南
团队
Community Protectors Community Protectors 的会员
Community
19 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 36
过去 30 天: 92
总计 1,270
