跳转到主内容
How to Flatten a Folded Poster
你所需要的
  1. How to Flatten a Folded Poster, How to Flatten a Folded Poster: 步骤 1 中的图像 1,2 How to Flatten a Folded Poster, How to Flatten a Folded Poster: 步骤 1 中的图像 2,2
    • Open up the poster on a flat and clean surface and turn it over.
  2. How to Flatten a Folded Poster: 步骤 2 中的图像 1,3 How to Flatten a Folded Poster: 步骤 2 中的图像 2,3 How to Flatten a Folded Poster: 步骤 2 中的图像 3,3
    • Wet a paper towel and wring most of the water out.
  3. How to Flatten a Folded Poster: 步骤 3 中的图像 1,2 How to Flatten a Folded Poster: 步骤 3 中的图像 2,2
    • Fold the damp paper towel and use it to lightly moisten the folds.
    • Doing this relaxes the fibers in the paper.
  4. How to Flatten a Folded Poster: 步骤 4 中的图像 1,2 How to Flatten a Folded Poster: 步骤 4 中的图像 2,2
    • Turn on the iron, and switch it to the warm mode or the lowest temperature.
    • Make sure to not use the vapor or steam settings.
  5. How to Flatten a Folded Poster: 步骤 5 中的图像 1,2 How to Flatten a Folded Poster: 步骤 5 中的图像 2,2
    • While the iron is warming up, take out any medium to use as an interleaving sheet.
    • The medium for the interleaving sheet can be a piece of cloth/paper/tissue/towel...etc.
    • Don’t put your iron in direct contact with the poster.
  6. How to Flatten a Folded Poster: 步骤 6 中的图像 1,2 How to Flatten a Folded Poster: 步骤 6 中的图像 2,2
    • Put the interleaving sheet of your choice on the folds, and move the iron across the sheet and poster gently as you work on all the folds.
    • Repeat on the other side as necessary.
  7. How to Flatten a Folded Poster: 步骤 7 中的图像 1,2 How to Flatten a Folded Poster: 步骤 7 中的图像 2,2
    • The End! You get a flat poster now!
    • After this treatment, the poster will become very flat and most of the creases can be removed. But some physical damage brought by folding may be difficult to be completely erased.
结论
Manshu Liu
于02/02/23注册
145 声望
撰写一个指南
团队
UC Davis, Team 1-5, Andersen Winter 2023 UC Davis, Team 1-5, Andersen Winter 2023 的会员
UCD-ANDERSEN-W23S1G5
2 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 24
过去 7 天: 163
过去 30 天: 622
总计 18,651
