跳转到主内容
How to Fix the Scroll Wheel of a Wired HP Mouse
你所需要的
  1. How to Fix the Scroll Wheel of a Wired HP Mouse, How to Fix the Scroll Wheel of a Wired HP Mouse: 步骤 1 中的图像 1,1
    • Flip the mouse upside down and remove the screw on the bottom of the mouse casing using a Phillips #00 screwdriver.
  2. How to Fix the Scroll Wheel of a Wired HP Mouse: 步骤 2 中的图像 1,1
    • Gently flip the mouse back over and remove the upper half of the mouse casing.
  3. How to Fix the Scroll Wheel of a Wired HP Mouse: 步骤 3 中的图像 1,2 How to Fix the Scroll Wheel of a Wired HP Mouse: 步骤 3 中的图像 2,2
    • Remove the broken axle that has become detached from the scroll wheel.
    • The broken axle may be difficult to locate, but should not have been able to leave the mouse casing unless it has previously been opened.
  4. How to Fix the Scroll Wheel of a Wired HP Mouse: 步骤 4 中的图像 1,1
    • Carefully remove all circuit components from the mouse and set on a flat surface.
    • The circuit board is a single unit that should be able to be removed easily all at once.
  5. How to Fix the Scroll Wheel of a Wired HP Mouse: 步骤 5 中的图像 1,1
    • Gently remove the scroll wheel by pulling it away from the rotary sensory mechanism.
    • The rotary sensory mechanism is the small green component of the circuit board that detects scrolling movement.
  6. How to Fix the Scroll Wheel of a Wired HP Mouse: 步骤 6 中的图像 1,1
    • Place the scroll wheel inside the jaws of the basic pliers such that the broken side is facing up.
  7. How to Fix the Scroll Wheel of a Wired HP Mouse: 步骤 7 中的图像 1,1
    • Holding the axle with a pair of small pliers, place a small amount of glue on the broken end of the axle.
    • Be careful to not get glue on yourself or any of the circuit components.
  8. How to Fix the Scroll Wheel of a Wired HP Mouse: 步骤 8 中的图像 1,1
    • Place the axle on the scroll wheel in the position of best fit, and allow to sit for several hours to dry.
  9. How to Fix the Scroll Wheel of a Wired HP Mouse: 步骤 9 中的图像 1,1
    • Return the scroll wheel to the rotary sensory mechanism.
    • The axle should sit over the middle mouse button input sensor which is directly across the circuit board from the rotary sensory mechanism.
结论
另外一个人完成了本指南。
William Riley
于10/19/20注册
169 声望
撰写一个指南
团队
Texas Tech, Team S14-G6, Cowan Fall 2020 Texas Tech, Team S14-G6, Cowan Fall 2020 的会员
TTU-COWAN-F20S14G6
1 名成员
创作了3篇指南
一条评论
Props for the effort, but this will not hold for long, glued plastic will snap again soon.
bxsus - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 92
过去 30 天: 487
总计 11,279
